- Joined
- Nov 4, 2017
- Messages
- 10,460
Well I have come into a few of these lately maybe that one will turn up!
No. If you page through you'll see that the knurling was typically on the wall nearest the service end, not the drive base. My "A", "C", "C Special" and "D" sets are all like that. (EDIT: My "F" set doesn't have any step downs in machining, so the knurling is dead center.) That looks like an "A" set socket, so it should be 3/8-inch hex drive.Is the drive end the one with the knurl?
Yes, in the "C" and "C Special" sets, which are 7/16-inch hex drive. Same thing for the socket with a 3/8" service opening in the "A" (3/8-inch hex drive) sets.The one that throws me off sometimes is the 7/16! You can use that one either way.
DSCF2367 by wvwheaties, on Flickr
DSCF2368 by wvwheaties, on Flickr
Objectively speaking, if it had the extensions and the Ell, and since you're already showing the uni-joint and the ratchet, it's fairly complete. You didn't mention the little A Set, so I am going to assume it was not present. (D Sets, wooden and later steel case, included an A Set in a separate little wooden or steel case. You may have noticed a little rectangular slot for it inside the D Set box.) I hear you on the state of the box, but these aren't that common. Or not as common as the steel case sets, anyway. Few and far between, in fact. There are only a couple on this thread, and only one of those is more-or-less complete, the other one is missing the A Set and a few extensions. So the missing hinge becomes a minor point in that context.Still there, marked “$46 firm.” What do you guys think of that price?
Joined the exclusive BSP Co "D" Set club! And the even more exclusive Wood Box Wing of the club, to which even I have not yet gained entry!What have I done...
Please post close-ups of that marking when you're ready. I want to see if it's the same die as the "BETHLEHEM" markings on the sockets in the "Big Boy" (literally marketed that way!) 3/4-inch drive "F" Set.LesserSon said:Three of the sockets are stamped “BETHLEHEM.”
King Pressed Steel, Newton Pressed Steel, and Service Engineering - all made by the same or related outfits at the same address outside of Boston (Newton) under different brand names. Is it 1/2-inch hex drive? Or 7/16-inch hex drive? The King/Newton/Service Eng Grecian urns are 7/16-inch hex drive. Link here.LesserSon said:The curvy one...I know I’ve seen these...
That is the same "BETHLEHEM" stamp that is on my "F" set handles (See Pic 1).Socket close-ups: Cold-broaching. “BETHLEHEM” font. Fractions. Rust.
I’ve got to disagree, Lugz. The B on yours is larger than the other letters - mine is uniform height. The Es on yours seem to have the center horizontal stroke at midheight - mine are just a little higher. Your M has a central point that reaches the baseline - mine doesn’t. It’s not the same stamps.That is the same "BETHLEHEM" stamp that is on my "F" set handles.
