Wiring VFD to Delta 15-270 Drill press
Davefr
OR
Yes, the enclosure is likely a starter/heater relay circuit which is not needed with a VFD.
The three phases of the motor get wired direct to the VFD. There should not be anything between the VFD's output and Motor's wiring.
C
Crawl Awah
DFW
Thanks. I got it working.
dogdog
how does these things deal with emergency stops ?
mikehaugen
Northern IL
I would assume they are the same as the slightly better ones I am familiar with, where there should be 2 terminals that need to be connected for it to run. If you don't use an e-stop then they get jumpered, otherwise put the nc e-stop between them.
E-stop will always be quick-stop if I recall correctly, a slower stop can be programmed for the "regular" stop circuit.
Davefr
OR
Mine has a remote control panel at an arms length reach. It controls the speed along with start/stop. The VFD can be programmed for acceleration and deceleration time. I believe mine is programmed for 3 second of deceleration.
It will stop in 3 seconds but not at the highest RPM (ie 3000 RPM). You need a VFD with a braking resistor to accomplish that. The 120VAC L510's aren't setup to use an external braking resistor.
MattT
VFDs built in E-Stop is typically Coast which instantly kills power to the motor. It can actually take longer to stop than a normal controlled stop depending on how that is set up.
