Getting a quote for insulation
191185
Hello
Located in Minnesota
Getting a quote today for bat insulation, vapor barrier, and then plywood walls instead of sheet rock .
the garage is attached, 20X27, one wall is finished ( house side) one wall is the garage door...
So basically two walls need insulation and plywood walls put up.
What is a fair price to pay ?
I have read on here a good company can do it for the same price as me just buying materials ? is that true ?
a local company is coming over tonight after work, so if the price is fair, I would prefer just go ahead and get this started ..
Justind97
Ottawa, Canada
ROXUL is around $50/bag @ 60 sq ft per bag.
Vapour barrier is $30 for a roll
plywood is regional. $30/sheet around here.
Time to do it with a buddy, maybe 3 hours if you're slow.
The Cobbler
my experience is, having blown in attic insulation done , is the same cost as just buying batts . win
buying batt insulation from the insulation guy is cheaper than retail store - win
191185
ok, $600 for insulation and barrier, that sounds fine,
$800 for plywood walls, that sounds fine.
What if I do decide to the ceiling, in plywood, with bat, or blow in, how much should I expect to pay for that ?
191185
Was going to try it myself, but was reading on here, its almost the same or cheaper to pay a pro to do it ?
benjamintmiller
IA
I live near you in central Iowa.
I paid a local company $1574 to install R-49 cellulose in my 2016 sq ft building, or about $.78 / sq ft.
I had estimated that I could buy the insulation on sale at Menards and rent a blower for about $1100. Menards rents the best blowers of any box store around here, Krendl 425's with a 14 amp blower. Using Krendl's numbers, that meant 8 hours of blowing with one person feeding and one person blowing up top. By contrast, the insulation contractor had a box truck blower and blew 100 bags in about 1 hour.
kTHREE
MN
I'd just do it yourself. I had a few quotes for blown in insulation in my attic in the metro area, ended up being about 60% cheaper to do it myself. I just ended up with batts anyhow for the time being.
Please for the love of your back, put attic chutes in before closing up the ceiling even if you don't plan on insulating the ceiling. Pain in the *** to do those after the fact.
Justind97
Ottawa, Canada
Based on the numbers I put, figure out your area/ square footage and costs and wait for the contractor's bid.
The you decide. If they are within say 2-300, have them do it. Anything much more than that and I would be doing it myself if I were you.
Personally, I'm a GC so I would do it on my own anyways. But that's just me!
Dzlpete
Williamstown, MA
Technically, "heat" radiates equally in all directions. However, "hot air" does rise.
Depending on your heating system, this makes a very big difference.
mike93lx
Richmond, VA
Are there any state or utility incentives available? In MA, they pay 75-100% of some insulation upgrades. Funded via surcharges on utility bills
ard
Sierra Foothills... California
why plywood? Looks like ****, IMO. Especially for a ceiling.
Are there any safety/fire code considerations when placing wood on walls in an attached garage? (Yes, his shared wall is sheetrock....)
191185
I would consider sheet rock, I was just thinking if I did plywood, I wouldn't have to pay someone to "tape and mud" ?
191185
You don't have to tape and mud. It will look better if you did. What about seams between the plywood?
I was thinking of using wood colored caulk ? what do people who use plywood in shops do ?
Gnfantic
Long Island, NY
I am in the same situation . I am doing my roxul right now by myself. On the walls sheetrock will cost me $5000 in paying someone to install and mud. If I do 1/2" plywood myself it would cost me $1000 in material
mike93lx
Richmond, VA
If you can hang plywood, you can hang sheet rock, plus sheet rock is cheaper.
Basic single layer taping is easy, and isn't required.
AMFJ
^agreed. I'd rather just pay for sheetrock work. Tried and it was a nightmare.
Tduby
Da U.P.
I wish I could have gotten a guy to install at what I could buy materials at but installation on the walls was like 3x material cost. Blowing cellulose in the ceiling cost about $900 which honestly seemed fair on a 36x80. I didn’t have to drive an hour to menards load the trailer blow for 2 days because the rental machine ***** and then drive back to return the extra and machine.
ard
I know, right?
IMO plywood sheets nailed to the walls look as bad as sheetrock sheets nailed to the wall.
Yet people feel sheetrock MUST be taped.
I did a shop where I sheetrocked the whole room, then did 3/4" tongue and groove shiplap up to 42 inches. Looked nice and clean.
tonyciambrone
Northern Illinois
Menards machine, at least here is pretty good. It is a Krendl machine as stated earlier, two 115V inputs (hook to different circuits). If you have a good helper and the aperture (not sure what to call the opening of the chute) set correctly, you can blow about 20 bags per hour pretty easily
