I've chanced upon and purchased a reasonably priced Powermatic 1150 drill press rebuild project.
Serial number (2-S820) dates it to a 1962 I believe.
It is a 1/2 HP 3ph, 5 speed step pulley, tilt table, bench-top, rounded pulley shroud version.
Though it ran just fine when I demoed before purchase, during dismantling at home in the garage I determined the motor to be quite far away from anything that the NEC/UL/OSHA would approve of so I will be doing a full replacement/update.
I will be operating in a 220v 1ph garage.
I prefer as many of my machines as possible to run 110v plugs, but 220v is OK if it saves me money on a VFD or motor.
This machine will see light/med duty home shop use, max chucked bit 1/2", on roughly 50% wood (6x6 timber down to plywood) and 50% Al & steel (5/16" tube, 5/8" plate, occasional thick stock bar of Al), maybe some light Al end milling if I'm feeling frisky.
Searching for a replacement motor has prompted a couple thoughts I can't seem to track down consistent answers on..
Should I double my motor HP to 1, or just one click up to 3/4?
I've seen some people discuss a 1/2" bit in 1/2" steel as this machines max... Is that with a 1 HP motor?
I thought a visit to my local electric motor shop would be helpful to rectify some of what I've read online thus far with real world sales/service experience, that sorta worked out.
My local shop said if I want vari-speed and reverse I have to have a VFD, but that VFD's can only be used on 3 ph motors, 1 ph cannot be controlled with VFD - Is this true, only 3 ph accepts VFD control?
They also said the motor has to have special internal wiring that is induction motor rated. I haven't seen/recognized this information in any of the motor upgrade posts Ive found on other sites/forums. - Did I miss a major point early on.
Thank for any input you can throw my way.
Better to pay a little more for a low end name brand drive IMO.
