Pry bar holder
hoston23
godley, texas
I am in need of a pry bar holder to hang from the side of my snap on epiq locker. It needs to be able to hold about 10 bars and the longest is 54 inches. Help please
G1GRANDEUR
make your own, type in google DIY pray bar holders, you will get an idea.
fourjeepin
Atlanta, GA
I planned to build one like this, but haven’t gotten around to it. Unsure who’s picture it is, but i saved it from this forum Oct 2015.
Shane6377
I made mine from a pieces of 3" angle aluminum. I just drilled holes to hold the pry bars. My longest prybar is 36" so that may not work as well for your 54". You would have to lift the bar 9' high to get it out of the slot!
kbeefy
Harington, Eastern Washington
I use a OTC holder for long prybars, breaker bars and tire tools
I made one similar to this from C channel....
Lower 'shelf' extends about 5" and is notched for prybars, pro-prod, breakers...
Upper 'shelf' is about 3" and has holes drilled for whatever (screwdrivers, extensions, ratchets...)
LB-1911
Northwestern Il.
Worth a look -
Part No. 13070H can hang from a welded cabinet or attach to a wall .
Part No. 13070L is a box-lip mounted rack that can hang on the edge of a cabinet or toolbox using magnets.
Both racks can hold up to 12 pry bars
Mayhew™ Dominator® Pry Bar Storage Racks
619DioFan
San Diego , Ca.
I added one of these to my HF 5 drawer cart. just a DIYer but it works fine ( couldn't close the lid on the cart with the bars in the appropriate spots. I did have to open up some of the holes on the sunex bar holder for the larger pry bars ( used a step bit , no problem ) also have long extensions and long screwdrivers in it.
