Wayne Dalton Idrive parts question...
mjz
Houston
I have a 10 year old Wayne Dalton idrive garage door opener. The short wire that connects the moving arm 'thing' to the motor control board (3 pin connector) has deteriorated. I saw sparks fly on the last open and it's shot. It needs to be replaced, but I can't find where to buy the part. Any suggestions? I don't even know what it is called or what it does.
Also - how do you remove it from the arm? (The 3 pin part easily removes, but I can't remove the other side. I don't want to break it.
carlosh
Stafford, VA
Wasn't there a bunch of unhappy folks over that idrive system? I seem to recall I steered away due to reviews or problems
mjz
Houston
Can you post pictures? Several views from sides? It was assembled,so it should come apart.
Image attached. The white wire is the one I need to replace.
mjz
Houston
I hate this system. Wasn't my choice, I let my builder talk me into it.
NUTTSGT
Northern Central Ohio
When they got bought out, the I-Drive was the only thing they didn't take because it was problematic.
OP, probably want to start looking at new openers. I highly doubt you're going to find any replacement parts.
I'm surprised the gears aren't stripped out by now.
gml1998
My I drive crapped out a few years back, WayneDalton quit supporting it . I ended up buying a l Postmaster Jack shaft opener.
