Tysonbrown1
Heard you all were a plethora of information when it comes to all shop related question and ideas. I’ve looked through some of the threads but have yet to find if anyone has tried what my mind is dreaming up! I’ll keep looking.
I’m building a lil shop in my back yard (50’deep, 100’ wide, 18’ eves, 27’ Ish peak) and looking into hydronic heat via a heat pump style water heater. There will be a small apartment taking up 20’x30’ of the shop with shower, sinks, washer etc.
So in my head I will have potable water via the hp water heater that will be incorporated with a heat exchanger to heat the floors and not contaminate potable water.
1: Has anyone incorporated hydronic cooling with hydronic heating system?
My though process is Possibly Installing valves just outside the water heater so in the summer a person could kill the hot water going to the heat exchanger and then opening valves that go to a buried piped loop 6-8’ under ground out front of the shop to take advantage of the 50-60deg cooling properties of the soil?
2. With heat naturally rising and heating a room evenly, and coolness staying down low, will I need to find a way to circulate the cool air and get it off the ground with either installing large ceiling fans to help push the air around or a return air duct on the ground to **** up the cold air and and then duct work throughout the ceiling to circulate it?
Or does it effectively cool the room without all that extra effort?
Thanks in advance for any advise everyone. Positive and negative feedback welcome, helps me know what I’m doing correctly and what I may need to rethink.
and that’s why I’m on here, needed some “real life” experiences to help point out the flaws in my planning. I will probably still do the hydronic heat through the floor, and look into other ways to incorporate cooling into the building. Guess I’ll just have to figure out the most efficient way to go, mini split, forced air. Any ideas you all may have are appreciated and considered. Thanks
