subarub4
The 2-ply gloves?
Harbor Freight make a great living knocking off USA designed and manufactured tools and are too lazy to ever actually improve or innovate anything. At least some of the budget tool distributors sell funky new designs and commission new products. Don't be complaining about losing jobs overseas if all you worry about is saving a few dollars on tools which may or may not hold up for more than occasional use.
Is that the A frame (if one exists?) or the H frame?Harbor Freight 20 ton press. Epic fail. Broke the first time I used it where the bottle jack meets the frame. Also tons of play in the horizontal moving part.
About Bluetools
Biography
Main interests and many years experience fixing cars and various enterprises related to electronics, but much of my time is spent designing new gadgets and promoting BOJO tools in Europe and non-USA countries
England
Interests
Ebay, electronics, messing with old cars
Occupation
VP Marketing and Product Design, Bojo Inc.
I have the 20 ton H frame item 32879 and it has performed like a champ. What was odd, IMO, is that it did not come with a handle for the jack (nor is there one pictured).
I upgraded from the 12 ton A frame item 1667 which I overloaded on pressing a wheel bearing out and the ring up top which holds in the jack broke causing the bottle jack to launch outward (thankfully away from me).
Sorry for my ignorance, but what is considered the "cast bottom plate"?Every review of one of their presses that I've read includes an update that the user ended up breaking the cast bottom plates that the press pushes against, often resulting in serious ill effects. If you still have that in place, give some thought to replacing it.
I wouldn't have a problem paying more for a certain tool if the quality were actually better and still made in the USA. Take Vise-Grips for example. I was at Sears the other day going to buy a new set but guess what, "Made In China". Why would I pay $40 for something I could get at Harbor Freight for about a quarter of the price.
Back to pass/fail. Has anybody bought the pintle hitch reciever mount and pintle hitch hook from here? I'm in the process of buying an old military trailer that has a pintle hitch on it. Still undecided to go with the traditional hook or the ball mount combo. Here are the links:
Pintle Mount:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95407
5 Ton Pintle Hook:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95408
Pintle Hook with 2" Ball:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96198
I assume you are upset because HF sels a cheap copy of your "Made in USA" non marring Pry bar set!
Bojo non marring pry-bar set(one of manny): $15.95 Made in USA
HF copy: $6.99 Made in China
Anyone have a pass fail review of these???
Chris
3/8" Heavy Duty Composite Ratchet ITEM 66313-2VGA
I have had this ratchet for about 6 months and I really like it! Only issue is the selector is backwards from every other ratchet I have. Overall MAJOR PASS
Chris
I have the HF yellow ones. Got them on sale for about $4.00. Worked great for removing interior door panels to replace a window motor.
Has anyone tried the jumpstarter listed in this month's ad? Just the basic yellow one without a compressor or light, I think it's fifty bucks. Don't have the ad in front of me.
Also, does HF have a good battery charger? I don't need the heavy duty wheeled one, a simple self-contained electronic unit will do. It'd just be used for maintaining battery voltage when flashing modules and keeping some batteries topped off.
I used my wife's teflon coated burger flipper for that!
Wondering if anyone has had experience w/ this electric lift.
$380, but with 20% coupon, and tax - out the door for around $320
Thanks!
Harbor Freight's Lug nut Torque Multiplier (33 times gear reduction!!!) gets my PASS vote as it saved my wife's **** ( well to tell the truth it was a kind Samaritan that changed her tire during the dangerous rush hour here in Chicago). The lug nuts would not get off using the breaker bar I leave in her car.
Luckily she remembered the new torque lug multiplier I had got for such a situation ( after getting new tires, which were probably machined torqued to 125 foot pounds, which become 200 or so foot pounds due to friction and rusting!!! [ my brother who is an engineer said that a 125 pound machine torqued lug nut would need considerably more to take off as friction and corrosion would factor in the loosening power needed to remove the lug nut and breaking the stud may result]).
He recommended the HF torque multiplier as it had the capability to remove the nut with out breaking the stud as it turned the nut ever so slowly and thus safely. He said that torque multipliers were usually in the cost range of 3 to 7 hundred dollars but if the HF model worked only a few times it was monetarily justified.
It cost only 23 dollars and on sale it is only 19 dollars and change. A tow truck would have charged around 80 dollars in rush hour traffic and of course it would have been much delayed due to traffic.
So the cost to risk benefit was excellent for a "Prima Dona" in distress.
6 Ton Jack stands...3 out of 4 PASS...1...ah well lets say FAIL...
My brother had his little honda up on 4 of them removing the ****** and went loose loosen a bolt and one of the stands just bent ond dropped the car.Luckily he got out as it started to drop.So to say the least he got them all out from under the car and is not using them again.
3/8" drive 17" breaker bar....PASS....broke loose the crank bolt with ease
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=37391
I have had one for maybe three years and used the piss out of it and it has not failed yet. I even had a proto breaker bar break on me and I had to go and find my HF bar to finish the job.Fail. I broke it the 1st time out. The 3/8" head sheared right off.
