Unfortunately got a dud on the 1/2” flex.
The minor issue is the direction switch binds in one direction. Operates normally in the other. I too have the original 3/8 and that switch was stiff but normal. There’s something off with this one.
The major issue is the flex joint. It stays tight until about 30-40 degrees from center then loses all tension and flops. This occurs in both directions regardless of how much it is tightened down. It would appear the assembler also encountered this and their solution was to tighten the screw down even more, which resulted in a partially stripped out torx head screw and that’s how it was shipped.
I’ll definitely be contacting SK and Epsteins about it. That sort of issue shouldn’t leave the factory. Especially when there’s a visible indicator in the torx head.
Positives are chrome is flawless, head as expected is compact, ratcheting action is great, and the ratchet has a nice balance to it. Maybe a little top heavy and I’d prefer a thicker handle or a CG, but overall a candidate for regular use with a proper working copy.
Another positive was the selector was well situated. Not a hair’s width from the surface of the ratchet head and yet no contact with it.
I didn’t put a socket on it, but the detent ball felt nice and stiff. Should retain sockets well.
Also like the length. I have a 24 inch ratchet and breaker bar for leverage, but 15 to 16 inches feels to me like a perfect length for regular use in 1/2” flex. 17-18 inch like the Snap On, Mac Axis, and Matco offerings seem a little long for regular use and a little short without “assistance” for breaking loose.
