New SK Teardrop Ratchets
asm154
Just snagged the 15” 1/2” flex.
After trading in my Matco 18 incher for a Snappy 24, was in the market for a mid length 1/2”. This should be :thumbup:
Skin
Boston
I’m trying to decide on whether or not to get the 24” 1/2 drive ratchet. I know that snap on moved their 1/2 ratchet cover plate screws on the dual 80s to the back of the ratchet head for a through screw design after experiencing them loosening. Has anyone here experienced this with SK’s cover plate coming loose? Thanks.
MAC switched their 1/2 and 3/8 Axis ratchets over for the same issue. The SK cover plate screws dont look particularly long so its probably a legitimate concern but they do look like a much larger thread than what either Mac or SO started out with. The SK drive gear is kept in place by a boss in the back of the head too so maybe its enough to prevent excessive pressure against the cover plate. You'd hope they tested it.
Mgdoug3
KY
I just got an email my ratchet was shipped. I'm looking forward to trying it out.
Wamsutta
Amarillo, Texas
Are they using a spring loaded detent ball and a series of dimples for the flex head wrist joint? The pictures I've seen on the web aren't detailed enough.
Fedwrench
Valley of the sun
I'll let you know when mine show up next week but, SK hasn't ever used anything other than friction on their flex head ratchets to hold the head. :dunno:
jsackin
Kansas City Missouri
Mgdoug3
KY
If the new flex heads are like the current round heads, it should be a screw. My old 3770 is a pressed in pin buf believe SK switched to a screw later. On Monday, my flex should be in and I'll know for sure.
gatlibs
N/A
Will you upload an image of both, side-by-side.
Mgdoug3
KY
Here are some pictures. The ratchet only had a very thin layer of grease (probably super lube) and I added a little RLL and that helped smooth it out. The head is thinner and narrower than my Snap-on dual 80 but most likely won't make any difference. At the moment, the Dual 80 feels better but when I first used it I wasn't impressed until the ratchet was broke in. I wait until I use the LP90 more to make up my mind.
The joint is very stiff and held together with a torx screw. I was wanting a 11" flex head ratchet so I don't regret my purchase. It's lighter and thinner than my other SK's but for some reason, the round heads just feel better in my hands. I wish the LP90 was available with a knurled grip.
For the money and COO I think the LP90 is a great purchase and ratchet. I think with use I'll enjoy it even more.
Edit: I forgot to mention the selector switch. It is very stiff but there's no way it'll reverse on its own. I also took the guts out again, cleaned it and added Super lube. The head isn't sealed like the Snap-on. There's no o-rings which causes thin oil to leak out. With Super lube, that's not an issue.
1foxracing
Tuscarawas Co, Ohio
Question for Jori
Is the inventory listed on you website up to date and accurate?
On the 13th I ordered the 80182, 80280 & 80290
All 3 show available stock but have not shipped yet.
vertguy
SE WI
Question for Jori
You may want to recheck the website as I am seeing a negative quantity for each of those models, which I assume reflects the number of open backorders per ratchet.
1foxracing
Tuscarawas Co, Ohio
^ I guess I didn't notice the - in front of the number, just green in stock..
Now I just got a e-mail from Epstein's saying it shipped!
Mgdoug3
KY
The LP90 is cheaper than Proto's P90 and Snap-on. I doubt there's any cheap USA ratchets on the market new. I'll pay a little extra for USA made.
Djosbun
I believe the prices shown earlier in the thread are MSRP prices and not the prices Harry Epstein typically sells items for. Since I found their site they are my only source for SK. They make Amazon's pricing laughable!
-- Dave
Fedwrench
Valley of the sun
USPS dropped off some Christmas goodness from Epstein's today in the form of SK 90 tooth 3/8 and 1/4 drive flex head ratchets.
First impressions: the direction switch has got to be the ugliest switch on the market :wtf: SK should have stuck with the green switch.
The ratchets have nice chrome, good balance. the head is secured to the handle with a torx screw. Friction only, no notches or detents. The 1/4 comes in at 5 inches long overall. It would be nice if SK would come out with an 8 inch 1/4 drive flex head. As for the 3/8, it comes in at a hair under 11 inches long overall. I'm sure many of you have heard this before but, i would have liked the 3/8 to be a couple of inches longer. :lol:
The direction switch on the 3/8 binds badly. I'll take apart to see if oil or something else will fix it. I'll take them to work Thursday and see how the perform. :beer:
asm154
Unfortunately got a dud on the 1/2” flex.
The minor issue is the direction switch binds in one direction. Operates normally in the other. I too have the original 3/8 and that switch was stiff but normal. There’s something off with this one.
The major issue is the flex joint. It stays tight until about 30-40 degrees from center then loses all tension and flops. This occurs in both directions regardless of how much it is tightened down. It would appear the assembler also encountered this and their solution was to tighten the screw down even more, which resulted in a partially stripped out torx head screw and that’s how it was shipped.
I’ll definitely be contacting SK and Epsteins about it. That sort of issue shouldn’t leave the factory. Especially when there’s a visible indicator in the torx head.
Positives are chrome is flawless, head as expected is compact, ratcheting action is great, and the ratchet has a nice balance to it. Maybe a little top heavy and I’d prefer a thicker handle or a CG, but overall a candidate for regular use with a proper working copy.
Another positive was the selector was well situated. Not a hair’s width from the surface of the ratchet head and yet no contact with it.
I didn’t put a socket on it, but the detent ball felt nice and stiff. Should retain sockets well.
Also like the length. I have a 24 inch ratchet and breaker bar for leverage, but 15 to 16 inches feels to me like a perfect length for regular use in 1/2” flex. 17-18 inch like the Snap On, Mac Axis, and Matco offerings seem a little long for regular use and a little short without “assistance” for breaking loose.
MWEric
Wyoming, MN
Just got my shipping notification yesterday. Mine will be here Friday. Too bad I’m leaving for Ireland tomorrow for work��
Got my 1/2 drive SK80220 a couple of days ago as an upgrade to a 2008 craftsman. The handle is a lot more comfortable and when it comes to using it in a confined space the increased tooth count really helps.
Fedwrench
Valley of the sun
UPDATE: I managed to massage the direction switch on the 3/8 flex head by removing the gear cover & applying a couple of drops of oil to the switch area, then working the switch back & forth a couple hundred times while watching you tube videos. :wtf: It moves ok in both directions now but, with higher resistance than other ratchets i own. At least I won't have to worry about it changing direction on its own :lol:
On a side note, the ratchet head isn't sealed so, whatever you lube it with will weep out of the direction switch or square drive. There's a ridge machined into the ratchet head in the base of the switch area that separates the two directions for a spring loaded detent ball cross over when you change direction. Perhaps it needs to wear a bit :dunno:
1foxracing
Tuscarawas Co, Ohio
Today I received my 3 from Epsteins. 3/8 & 1/4 Flex and 1/4" x 12"
wlSMAgPQ5KFTNUn5HQ2VY3s9cZUAajHLQVZsYYM357nrwmsHaKAdSObfbSN4r97KbJrf3oDn_xScN94L3A1OEV3pjAEuJvf0poWS-6Sst211iJLaSqzTnwf_R8eFKBXmMs8ql9c0yTxZM4pCNhfzaJ1c1JKeFgJ3M6j9j8afO2UWieFGDL1nML6NC3bML3UaGZE8WbmGEhjv9cRPJcnKuSfP3ski97iD25pqQHuYGWuP2d2frtVqy-GmvwWwCxyZRwn6XsO3ZHX1C77TcukCxxq6UFmu3GQR_p91gCMYLO6cSNkMzxyqZdIPoNU-QLMcztOBlJH-DpOmcFO1lCS6VQGPPn95ryCAWtehROTz1Vlf_8w1E5BkEYo-x1svRdFLvBog8ijyw8RhPO9lmyTdWfihChQzotmZ-Dk2SX6GAQzMBHgbTnwiAizlvp_98PHadeLVtGPc5XyLORmq87d-Goy4kgkB21XrFgXHoZ6q9M1Zw-zbvobsQhmDP5XXHzuu9qYh4x3uQMSSWjidKIpVQ470zQVgC4Ik6HxCFSlGB7Sx6ahLaEWeTkrSihbWNGaaMcy2WBQ9UjMNrm970WTH6WLNDQo1FunoWIwpBdBB7J4Vohi8-y9AwrF0ec4ABEwSCy8dumK2FQ1He7-mSwwcNlkNeDzLl-Jiy-YvTbrnTL8qfZOjuHaNW3tTxpwdERQx9rwATGeq8V3dicZqYSbYfDL4wbCg3BN9WGN0NTfEEYGZMx6UOA=w463-h694-no
cZtq3iDBoquGV9g5k6WLX065wWyOvfFosPq7DrJqZyv2YPmi2UGHFOW1_Riw0dWlZFDQV5ElNsfqY8u-diqBZH6XWThhnGyqFCvKx5tDP135gCCVP3EYn40Lw6wAWnMLy-1ut67Z9GPNGLXlsepN_SlR3dGu2bTyvEHIHp_oCK5tD-Lh6UYmQ8cxl3Ha9Bew6CflG1aBwKE_BDeyQtzTqFqeG83Ok9WB6M6wA_xV3R5xaOwuHy8gXji55Om4jQBDwsbmVYMeZ79JyrOuwQI5fjmVr4fYC1eYpK7d54aXo7h7jaqzlbGO3j5x6DovgWhU3XQocqzFxb0_8EH5mClhvDeQXUswv8p6ZW8kw2rTg0FDd6tOnuez6lAxXi729ntwY3Pc4wK4Ha2T5dpT0DpUSw4LxGGRvSfJc4D-ptgbsEdRdEU1TTYGziJWLGLbSjR5I5MNERycrr0rzWQeqJsUJgkh1DVYVy4ENXG4JkzGwJIU-b5lF2DUpPoEf3Ft0SpIjBvmchNTi52O2owGOUSkbAgFAO5PyDNzAgzMySG1jxcUJHnWK20JOrs1oCb20sDnvIDOvSxsUgFgK3KAhDy7pwqxqfWJSLAXpIgfBh-sgK7odQy8qJ7WLOfB3kCsnmE2lfsS5Tv0ZRqSsXOKQJlmKaO_8eAYh2jApzLkTUo9MiH29wpDmQsE25cU-ATKYNyRNYsSICpk8swO3D5eGiuQW0CRFf0K-SHOggpIcPsV977UPw0hJg=w1043-h694-no
_QKw9DJm_vMdQlilxRrf_aDH6JRKwX44UGXzsergIk88zjXL4iSsMXFKyn_1doApjaCxdNom4iLK3zcqQCB3AeGtV72EtvOtHgvqv_CEDtMnm6pELhomeQcf9DFmQ3LCAV4i3aCj8wt8gGfTnKCfJlkXsYRBCpT8elRRbJ2XTvCCfaIteLKijiFdtiiwkkCHDklVtS3hakN5CkUY7ahzmYkd6ZgZFrYu5V_ilaw4-1e-RzWQPiiiUCvaLfgFw0X7drsI3IJKETyZQvt_H_hX7UvIUVenst0b4hQNaEcuuz-A69iyoNHNAfaktNBVKbOXeUu7ZnBY4fWW73R8Ut_zWOSr9FrwytQkvbqQRxWrOEtboFFO-Msu-66lsf8-BR6nCz3o9P-c5deGXEwGFX9IWEKPnzPfTVXRtSSF02K1_nvPL7_YVDo1Lk6byrpkQE4YlGZ5aSfgob006V1YRUhBI-IEk3pz5fWnIH1iIikDOyN8DuBV67Ov1rVAOQwpGHDEh9W-8Sa_mriImWS2b1cFxb3_eDBSWcJr5fNrSzUfkorZJCZHMvgIG5xtgN8zGeM4g42kO8splYT67PXtG8eXHNKILxxCYUN0PHYVQcqXy7THuIraEzkIYnpbC-qSplVC0myupvmMCfMNtOgeR5Ll_q9q5y6DzhAqdVuamdwAdy8i0gtWa1JZeT_zwabJdXZKrvG5yi7vXq-JjV2gX77jp6Ko9vaotJiAL8omR2xj0J52dfbg1g=w1042-h694-no
DR09FyWwn5VW4zTGlf1yRAlHY870CvlIgWpEcZqYBFaF0OjogZkftydwqb2qqTOeWY5vATZUhreg-6k5rYM_bJbXaakGZ0_WgPT2V7HvVzM2evk2tQWM6UyxuNoGRJKS0Ozwr3AY75PJDrpWibJMKX7jQMGkVbPquEFPcB_8oggKCFJLxEgjmcXgUKaebldNmCgwZQkFeYxc_kylTCSUd_Q02hirDUwZjhAKU4LN3ir3f4t8QAA1pCs_J8aTZF5KLNY4iphlmqesHxZ0t8tB4IuuuxisDcaBtEdjV85htmiNSZUyZBPEmwjBzMn7ijNzVhgLj12z66dKJcTF7Nn4I_DclS3stAVGJPSg58QTkWHbqHilUKdhC6USPzw2-WfpkxwpxsH0CZm-ZWKVlPgIA5prnsxzmL20hfSz67N2n4Q2aHoOHr4XaGqH03NmfriZYC8EiaRGg2X14RIMpgwmTG9k2lPMjqyJMTlCZoR61qcsRB4-exEPgp2Z-5Ywo54fGtvgJG4m5p_ZqKPDqSVSfrIAR4jfIZkPT41eWSFpaRl3eIORPiObu4ovF9XUJ21JSVTjA06SDR1x3FicWqDcIEfEj5f3uBunOgZD3kqakjf1hWT-JTFNwBN_rQh_npmd1w5me9m0u5hbbuD2nt66Q8Eg1dgLO3YKXorkIOeVvxoLEmVWbUHjWpdz87SOV-uij5BcHolOqxuqVK_xx23y4Q7OsMp5C9a76WBYlB3xXckLYISvXg=w1042-h694-no
nBAooazU9H_PMDSvI-1Gs8QL_jR6i89N8-VgzftV1BIUWRGTEzVHRU_nupma3PxdgnXlLHBZRs20dZsnF5E8E9CkVM8Bq3vFHAVkikIvNPqiX7BavMmIBUqgLJVV115HpI45lCv9hO-ZJGfA2yH8v12aEUTm44vkCY4KeZNj7O4Psqnxu-CqQ2lNBxyBQ3tvJV1Ib74EZMcp3vkcmwRg0folGG2Zq06h2Gfq78Jpx0TcCCWPPUCQrMdeVrDdrjuU-Bt6lBuItFkrhZ_8aAgR6DOjymnrwFWFgLNkL5V7cFrg_J80YxRGoQY9_poZJhibZbOCVYIi5229oK-0eq-rc39kdu85zTaAND5w8AXTJrsKXsDJNZj8WCm8I2gmmVZvrAtr_liuBflZZa54RvWMPeDRRiLUECKIYZ9jAwooPMxre0ICJLDEVgpYHX9145e0JmUAM41ui7kGzGGIgr66YQgwmAULQBqbi-d6Y9hxuA0_P2SAk16Li_Sb5rDAoAkIT6X7V_ns3uFmy0H4kbSuhPEv48EqNsFA9Vl-UlOiSSeYKKTvLfgbsS01JGTzNglZUWTvNfRJ0T-s3Q-AELaHmbmaPsap_vfoQs4w5OXFbwvGOV6DWL8XuySXhZRWcuqdoHiKArQMifJ5Pu3g1JGKToEROR5tNUblemU1IHLLGUbzVCuPvVEL5z03YEzVjAKokJbCIwbS1fVdLesPPgZn_zLiaRiwIwuNzxi_Bq_5tcIY0c8fTQ=w1042-h694-no
n3j7Nap_f5ef_zBEjsKyNkZnl8GDVR8gaVhMMCwxilcou4ODohWvvF7DvoWzsx4klcR1Ne2nyuP5Ptut1HziftGQmxMo3kh40wbKNN6bzPJv5gOhX10OiXgLf0KSAKEjfHaXwzDUotkIh2qhOG59d-K3mBUgT69YNGejSNvEaHdmoeJMhP4xUh1x_P-DlHCtppTTHjUM2m6IhAreOnnjgt3McHr_oaL46XPu6XZ2nGnkCEdo9wy_cFt5CFrmfz4TJix4_MfhPTKeFOlewJtT-geVFTmZw6ZL1ZAHZB7QB372naYqskiqGZwGFDSkYCP_aLicPFdO_K7eYkmGIsz1RNBNrmJ0zWU7_8hemeHWAgF8B9GxVlAFV4DQAKqjG1CtCX5stxwtfvGRb2PYIEjCumf-bb8eljKghxzw-eYSc3chiXattsowEy-Vv1gYsdNCHUSE54GyCy2m1JFzI8OustbSUorxopHWSN_hhGPm8ETmp9GAOIgAmb3X759iJNFf070yDRekPzPwTiLz6bYtzRo0YbgwoxMqE5pA7xG8qILvpWUr_Lt7zpzRzUwUFHfkjAkBUkgtZSREmGLZ1TFFRdvfVTn_T_9Qnflk-MJ9e0MIVRwr7mzzGrqiQH62sOqF8qHDKeEQe_ygIdzCUzjLxQEuGosNyg9tgMHE7LYazHqgc4VDIVBt_tnGMN-OjpQtm5XC34zm8xw9dxtgcxHkJZUJgWOWFDa2e-oKSMBvPIaGhsX6Vg=w1042-h694-no
R_Ko0VOl5RbOsvRrWQF9LgUw8edZEd7HvwUVszASW6VPrGBvuKMMh-m7IBMDPYQanmwHoZsETlcH9uPPRzW8utrNCue7PhsHkV2w76864XNoSKgcwJagfz8l5llgA7vi5IgShFOZ93fKy9dVi5MaSWtKvvhLiiiNAx0weTp5BqB0BsOjwiyOT1bA_tBKe-SoMWwWKgxdE4Gmi-oBDdRH__3Hj19S4mR9a04yZmxS49GNXQ83GJ5tJc1nGYbl90FGiXnJ3XecYsX816LWH2XJ8kUNwtejTPtAEAhYeirelNoUJqFYRfdRlT_2ZpQLc0wKdyytWmtVpn7Kkb4KcM3OgL6H9t7TuQ7gc4pnIfAIaZ1UksCkWFyJP8CYOBSGtuZS5_KveR4niVkTNuMS46X4t7sfsrR-GwVlnt_Kq1wodvW4wZok7gfBzPDv6wKMg4qHzxhO9Sv_cHbtruCQ2gRUEke1mWmbQEi3NQBdrTKmmzOtRTGHro-TRr4Gv_PJofCUoYPxangD1WfG5WWH8FndK26_opdjAxIFSNDkp_pyutcK12UKZ8XCIfs_vbWuVpIzPWwQ3BAT-U5sZK5-ycv1zZuVxMS7oJENKfqeKVVtAwpjRmQcy0YJRnIHcQxvUL2NX4L0BSD62nYzrZIV-HATujq0lVzycjwpsnzHZbZ0yGrkLyb5W-pHqMKklCHyRNc0KETtPHOXECJ-oW8J1MhLIZvHXZdjPLqhXJ5dq7M3OkThOozLOw=w1041-h694-no
DlexWfQZI0ZAPuQV5IljHTHsbmEmt2ovQ2UO15BeczwXSvKrWN0dtPl28dms1xNVaDffLsHQOIuFfcDLg88nN37kRcescPE82PeClkGHJbjUYbn40ZDJe0sAGPN4sHm8qeMM-3gh6AnIwAMXf_nshslxP3laQtXOtnaae4ZG-Bkfn16LuttG9kwoKjv4mHlk7a_xUGkEQm1k5s88UM_FICW64sKa2BoBsvcRBMjmzXP57iy25dzwzYu50NRU-d_Y_jHd0zwmxgKf858waVBEPc9A7LYcZWWwKI8G88Hu3ByP9Nr2b6qgerr0bLscFdqD9dcxJna_pIOoD1uXS3-GV01q2Sx6T4WQDXT21QfklLK8_SajuOxFcHBwNU-JI43U58ZHc5BjwtlhQhrmvynBJFP3-WFHBe5PAX1N7jId2mX9k54h0A0mnMsnTekQs3rMOvUB9EpIa-_73QyMvNhrIQeLaraZEDZW9a9UPFT3VK7ArhszgEnM-Oldgc3wrVHWmZ7ZmJciLkzcWO_Bq7VfXph3_Hz1q0EdkzgdBX52oTDzsJjiCevgcTHPTWrnYOqS-D32R4nolnpj8WC-i5RloAsnfyuL-a23xRbxeuz9qKfekw783e9mX8EfpdwZf2AWBXarDKam7ibrtN9kXsNdCS2-VR4Q-n7gs3TL9GmhWY9VGfhx9Xm1N19iP6w2FznC83O504Jx4FISIT1XQRCJY5elazzFGB02lusD3BkiJB03Ojp2jQ=w1042-h694-no
Hdy8QvPaVlrasf3VIfKFC5DmOfxkkeD9qpDlqBFCSzjiI162B8xMe9KX-xBeoPWTljN2rfIqR_n5Zjynspgk5YfJvSvVbA6uzflMAkNpPdXCdpCQrEdz79NiBSPmcZAC-FfKGoDk9Ya58YaMvsIyU0rPe3g_j2H9XW70PbbpQgrXheZAJxoM7cdxdun0-UaAxFUgApQ1khLItGoiikvGTykm6B4OY9uHoqqGz98fKpSUsiHEmPnXBEy9KeFg0-69mmfkyp71ULtveQxPXIiyjMcJzBY2vBAAVU134UG_0tEJzIkyq-irEFvTL37dsfbjfAOVEqqIU-hEmznslyTeEAivRMuqavlLQTefFHyf5V2Hb4CVn5yQx0slvx6D__EbqhuPM7z-R-olz2ueT3sBYTEl7VvK1sf2jyciyBCan5n1FOQqtIB9rjmz8XaUPC08vJ4CtMP8JNv_N-uey-uQoWXBS6snorA0oIMk6buZg5r2POTaX-aPRuZLLqH-o70EJaVGqawqfF1Hs10_GgQWJM6XKQxWwill1RL36KpmkNwaBilCRA_bnqNBwad6J3Bd82rqiv_Zhe_u0nxkvku4Bq43BF_2kfwo7ocexkPLxd8sIRh6ALTC2AegE6V0--4rwxhx6WBStllL37Z1Y9U-4TpRor8PcdaFqmqNfP_z6V-sOU3oQOaaJ-9eoRvTUZXCYTWrTEmsZ0W55WnnfmqaZfFeiDDw1B3CDYaa-El_LUo_kSVyGw=w1040-h694-no
Mq-QHgWbnOGcl7dwnZ7ZNvSNs-iVhEQPBFMRMdn086h46K6ceewebVOMIDnxnTCwRzUhfN9JvQ4wgpuqvEd9SdWrT3D7hRe-qRX-7dt3CYyR0H4GlezFtPpIIjDgAH4aqkkfSqRUMBIStyDeA-ffdxt3ALnCr-rg0kHDM4rCNPCh7LYxPqQDfk-7HX59OqzC22jDQneCTSylcF7_xNLqdfjhHEs4RULk6bJaK5r6seupKT2OoO45SVCQ55tXrVZkzO5S-fuhxUiqeuUqA-2xZgs1mSqDkGWFILYkYd7hnG1lJ1WXky1nG622ON6lY6dnlO4DIf8mw_QJ8V69WnhzUcR6ZZ_xDxDlciOBwKd3KFWWdsAHppwp9H1EGTXOxEVpCnYyLjytT1Q9JgUJ2GxWJgfMNptffidhkJPgjFt2MKNhTL6up5qXGkmyBLh3kFyGSMpvyxlN6TGl1wzDiDtzjVEL3N9x1d4aZ4Nqh664-GCCz91RU99Dit2iRUpz-T0bl9Xig8g-Y7aM00NNtEfMaB0SOKudSHD2vfZExaLgFNkqiUiSFjquGmNB19a_KXBNJcpBN-T86F03x7bCD6UCDe8SbvmghfGA7iDKa2pus-Z0RWKCz2x62iUtizPX0Y2GkSrOjqKpX9I8JZ3wI0n9FNAfQxrsS-ZBtaShruLBu4h-NLkaBuWQQ2sZy1m5n-P9fSyljWCT9mNoqvwul_OrFQiXc0nfVU_iNu7BCK7WETbFbGr1RQ=w1041-h694-no
RV0P-8UTj8TCkl16REDky0jIgLle9LaT-Ts1A1Uxwz8PDwQ68QZcrx_6Mvz4gqCe2R0aEVI9oC8JSXZDW0jrgN3OodNZ5oUC9Vb_wefZhOmetQnZraQ4JBS5wHGBHrYTrKNeSBgy6oFP6cor4ytOFsK4T919XdT4HreLUco2kyCkPkBBRYcGLDqOPZNT-CJUysZoCChoUYRzElOuxf3hXMcakM2wuq1GWjKfkUmAPvXtheviQhr3m80_YyJp5c6APhPmlNawDr1mstexQXaamUp117xrigepTbbZYn12QRSm8fykQjeMzgDqNZ750BdopYTGrfunTwo43e9gLzJSrd9-9_ED45uvhv9ZQmqzjelHYjDhPU3j7KRKGmqwbi_wzomv6OdHDhYPPwA-_zOZg_H1ZaxK3C1kEAQHMTFJBgFgW8643A8Ku7HoKJ9eMUUHtTwaTfg1QRIx6VGlI3OHWDwGZgPmnCH2B650cG-wwcSw89UscZnpk2-3saBmN-gegUL-Mq3CvVlT4m4hrg5MYT5UVHWCpm2sUpaB_sH-XsPA5vNxqpOi3cjE9GMZuuhlVqzC8ZFyFQvHCtLj8pri4UU8u0KZ4NGA7SMn5yuB3gHwGctDCsNPGD0rFXC19fIYsx9IMjtqsuHQdWy7nP9u4iV08JH6BPSWv_wWGp8gj23TLC7ARE-sVr7bEWPCDMRClED2kptVToMdUmAq06jSshoTxDhmtYcychU8dF7gTsd7Mm115w=w1041-h694-no
LLIaYm2LGse8sa5Wrlc2jL8cij6mM6kOg_vPIc1ikX6RFYJfcaz4-TCACysUdU4HOxgHkZ6xlnmYZM0xkpQ97EVia4JGqS266RqRBvypNcIIiAlGwXQY9t-WsH3PIlLDF2H7lF7n_XV_Kxog62eaRHLfIcMqjyvEOyNgS63oM63QrOYk1-vmUErDxNaKUVL_3N-AdbCA1vxt6tHCMtFbe74CdpE57y0eM-0S4EOk2_oLp_WRQyI8X0UdkseqN_Au-1NoXOwasfnYEcCNezZHpSJlpWJzwLN1mvqry3lnL2tu1htCtusCLy99UanaSsNXsIQPf43fwx6kfX8azOba_2Kb0EanCUw2IMq2VYQatDYQVmf0FXUUjjD0QyCS_vAQX9Xz7saV-v5Ow5dMJYyJ0cD6nNzeOgQrgIFti2Q9VYz9YcCzGMTRYuvwSHSE-9Nuu4Bu6mHXoCu-9cOs33x-U9r6PQ_4vm4qVJd12P5Fc0NT-NBnRfmrvCLANs993EBDfqOyBDcwP5UJ8tVUsQuLLb0phXyQn_6lbD7A0X1WItWkM178Jlaptf_UrYTpdEctWmxheYQXvoS3M8g3XHjqNlUsk37okwauguupJlVQqjgpFzASUHuZ8rxurobieJTdFXj664Qu5Xi8N8BMfKHqjbZtjClOrOuKx6IqUFIODQcMFlr3F54NCkDNMPjQSszGAfdcf0YPWIR8sCoUjXGCxWF8FMqINeC4dHjJd6aciEklpDulzQ=w1042-h694-no
Steve_P
Great pics foxracing! I have been waiting for these for a while and may eventually pick up a few. I havent checked the Epstein prices but the list prices are surprisingly high. I have a lot of SK, so I know it's not cheap, but ....
The length selection is odd. A 12" long 1/4 drive but not an 15-18" lg 3/8 flex? I've never needed the former but do own the latter and use it
1foxracing
Tuscarawas Co, Ohio
I don't have a 18" 3/8" drive flex but own quite a few others that all seem to be in the 11-13" range. I don't know if SK is going to make a 17" or 18" 3/8" flex or not.
Indexmill
Central NC
I WANT the GREEN selector!!
For what these ratchets cost us to buy, making the selector green would be an insignificant cost adder for SK.
Mgdoug3
KY
I have used the 3/8 flex for the past few days. The back drag is low but not as low as broke in Dual80. The selector switch has loosened up but stiffer than the Dual9l80.
The good news is that it feels better in my hands than a chrome handle Snap-on. The Snap-on grip doesn't fit my hand and always feel like my fingers are in the wrong spot. The grip of the SK is the width of my hand. Another thing I like is that the SK is lighter and is more aesthetically appealing to me.
I can't say I like either ratchet better than the other but the SK continues to grow on me.
1foxracing
Tuscarawas Co, Ohio
Initial observations are all 3 ratchets are shipped dry with no lubrication, I plan on lubing them with Klotz assembly lube.
The Flex joint is a Torx bolt and the cover plates are Hex bolts, kinda odd and I wish they would just use 1 or the other for both fasteners.
The selector switch is very stiff on all 3 ratchets out of the package and hopefully free's up a little with use.
The flex joint is not continuously smooth throughout the range of motion.
These are not sealed ratchets with gaskets between the cover plate or selector switch, I kinda wish they were sealed.
The chrome finish on all 3 is flawless and does look fantastic.
SK is known for great knurling on their round head ratchets and I wish they used it on these new LP models.
Out of the package my initial thoughts are the Proto 90 tooth ratchets are better at a similar cost to these new SK models.
bonneyman
Desert SW
Still waiting, not liking the QC issues. Thanks to those that posted pictures.
Agreed.
Since most manufacturers are going to a free-floating "Canoe" pawl I'm not surprised to see S-K move in that direction. I'm sure their metallurgy is up to par but the finish issues are concerning.
JiminAZ
Phoenix, AZ
Have owned the standard LP90 3/8 drive for maybe 1.5 years, and am overall happy with it after adjusting the selector mechanism myself.
I was thrilled to see them release these new models all at once after a ridiculously long wait.
Disappointed that the flex models are uneven/inconsistent in their joint friction throughout the range. I sure wish SK would get their QC gremlins out of production.
These things are priced in Snap-On/tool truck territory. I can buy new SO ratchets on ebay regularly at about 70% of retail, sometimes less. I find myself rooting for SK but just can't get myself to roll the dice on inconsistent product for the same money.
Jori is doing his best for us on pricing. C'mon SK get it together!
