montecarlo31
- Joined
- Feb 27, 2010
- Messages
- 52
Figured I'd show off what I got. Nothing great, in the process of re doing the back yard so the air compressor is moved back into the garage for now along with some of the yard equipment.
Once completed bikes, compressor, trash can, rams, lawn equipment will be moved to the shed or beside the shed.
The photos aren't great but I'll update as progress goes. Plans are as follows:
Install air reels.
Install Garage vac (between doors).
Change out lighting to shop style gas/arc free.
Grind and repair cracks in concrete (not sure on flooring since I need to keep a jack on it).
Insulate garage door w/ Owens Corning Door Kit (too expensive to replace W7 doors w/ insulated W7 doors).
Install Jack shaft openers on both doors (remove current 3/4 hp Evercharge lift master).
I'm sure I've missed a few items but you get the idea.
Install air reels.
