I was one who got burnt using Permatex purple in the past from then on I will not use Permatex products no more simply because they lie on their labeling
Thanks for info
Thanks for info
Super Lube is supposed to sell a paste that is safe for brake rubber under part # 97008. I can’t recommend Super Lube #97008 because I have never tested the stuff.
I use SilGlyde on all caliper boot type slides and it works perfectly, Permatex or moly only on metal parts like pads ends and backings also behind hardware to prevent pad jacking rust. I do a couple hundred brake jobs a year and when they need more pads all the parts move and nothing is stuck or rusted in place.
The Raybestos could be rebadged 3M
I always try to use what the vehicle OEM recommends.
I think some of the issues with rubber components swelling might be from using aftermarket brake pads and hardware kits. Who knows what type of rubber the low priced brake part supplier is using
The other issue is exposing rubber components to brake clean.
It's good to see that everyone has their favorite though![]()
The thing about Sil-Glyde is that seems to be one of those products where you use it 2-3x and then the cap splits in half so you have no idea how to store it after that... I think this has happened with literally every tube that I've ever bought.
Get a tub instead of the tubes. I have a tub and use small paint brushes as applicators.![]()
These are Metal-To-Metal only according to Permatex website:
https://www.permatex.com/products/l...kes/permatex-ultra-disc-brake-caliper-lube-4/
https://www.permatex.com/products/l...atex-ceramic-extreme-brake-parts-lubricant-2/
Here is the Rubber safe one:
https://www.permatex.com/products/l...licone-ceramic-extreme-brake-parts-lubricant/
Other rubber safe versions are available from the regular parts stores:
https://shop.advanceautoparts.com/p...-oz-bk-4/12024852-P?searchTerm=SILICONE+BRAKE
https://www.napaonline.com/en/p/BK_7651351
https://www.napaonline.com/en/p/CRC05363
The 3M Silicone paste would be included in the last list. The 3M Silicone paste is rated for much higher temperatures than Sil-Glide so would be more of a general use product.
Don't think I've ever seen the tub in a FLAPS. Still have two tubes kicking around. Wonder if it could be stored safely in one of those little clear takeout containers that the Chinese and Indian places use?
****. I just put rear brakes on wife's car and lubed the slides with ... Purple Permatex.
I have a new task on the to-do list.
SMA uses it on everything and says hes never had a problem. Personally I've always used straight silicone paste or Toyota rubber lube.
sberry, a lot of today's caliper pins have a small rubber bushing on the pin end. Putting chassis grease on that is certainly going to risk swelling it. There's plenty of internet evidence showing that certain car brake brands have issues with rubber swelling if you don't use the correct lube.
Many sources suggest using 2 different greases for brakes. One for the pins (silicone or Silglyde is my choice) and a different one for the exposed to weather metal-to-metal areas (pad ears and/or backs, caliper bracket slide areas, etc.
A very recommended metal to metal lube is the high moly paste Dow M77: https://www.boats.net/product/honda...MIr5vb7eTT5gIV7ffjBx2L4Qa8EAQYAiABEgIFJ_D_BwE
A number of us have found a less expensive alternative to the M77. It is also a high solids moly paste called PasteLub: https://goodson.com/products/bpl-2400-pastelub-brake-lubricant
This stuff has phenomenal anti wash off properties. I also use it on rotor hats, hubs, etc. to completely keep rust at bay....just paper thin coat. This works in the rust belt winter salt baths!
I bought a tube of green Permatex (product 24120) from Canadian Tire. I was told that is what the Canadian Tire mechanics use in the garage. They must do a 100 brake jobs a month. Back of the tube says suitable for entire brake assembly. Compatible with all plastics and rubbers. And now they tell a different story. I will likely chuck it out and re-do the brakes probably with the linked 3M product.
And maybe silicone or anti seize onto piston.
Check to see what base the anti sieze uses if you go that route. It may be something that'll attack some rubbers. Same applies to the moly pastes. The Dow/Honda stuff is silicon based but some others use oil.
