Craftsman V series ratchet, Help!!!
bratwurst
Wa state
I know, I already started a thread about my Craftsman tools earlier, but I can’t seem to find any info on this ratchet, at least not with this switch on it, any help would be greatly appreciated. The switch looks newer than the ratchet.
bratwurst
Wa state
So I found a picture of the same switch on different ratchet, I wonder if it got swapped out to the one I have.
DSLTRK
PHELAN, CA
Someone attempted to install a quick release gear into a 'Flying V' handle, likely due to not having the proper replacement gear.
The switch is for the flex head series.
bonneyman
Desert SW
Do you know why they did that? Is it because the regular "baby rattle" selector would interfere with the flex?
bonneyman
Desert SW
If you had a broken selector, and a older or malfunctioning ratchet with a good selector, and could make one that worked, why not?
Most likely, it was a convenient readily available piece to replace a broken selector, which happened frequently. (particularly when some numbskull you loan it to uses your ratchet as a hammer).
That's why I don't lend tools to my friends....because I tend to lose them as friends. :(
bratwurst
Wa state
If anyone has a selector I can have/buy let me know.
I wanna make the ratchet look original again.
Tool Pants
San Jose CA
Someone should put that ratchet with a mismatched selector out of its misery.
