danielbuck
- Joined
- Apr 15, 2014
- Messages
- 921
I'm making space in my 1 car garage by moving the air compressor outside. I'm going to enclose it in this 36x24 "shed". Tank is 60 gallons, compressor is a single stage single piston 240 volt 4 hp oiled motor. "industrial air" I believe the brand was, but it's probably the same as any 60 gallon compressor under $1000.
I've added lower vents to bring in cool fresh air, (there will be one on the door as well) and my initial plan was to add a fan and somewhat of a "chimney" to help the hot air escape.
After I got this far on making it (the roof will be mounted better, and have roofing on it), I started wondering if I just put some mesh at the top in the gaps between the roof and the sides, would this alone be enough to keep their compressor cool? Or should I still look into a fan? I've outlined the gap in red, the same gap is on the other side. I've made it about a foot taller than needed, and about 2 feet wider, to give more air inside, and also a place to store yard tools (rakes, shovel, and so on) But for the most part it will be just the compressor and tank.
I had a fan and a chimney before when I had the compressor sort of enclosed in somewhat of a box in my old garage, but I had the fan always running when I had the garage lights on. I don't want to have it running all the time, and I haven't figured out a good way to wire up the fan so that it turns on when the compressor starts, but keeps running for a set amount of time after the compressor stops. Ideally if there's a fan, I think it should run for a good while after the compressor stops. The other alternative would be a temperature switch I guess.
The compressor will not run continuously for very long. Usually it cycles then stops, and repeats. for the work I do, I don't normally have the compressor running continuously for much longer than about 10 minutes when I'm really using alot of air. (lots of angle grinding, or when I'm using alot of air to clean up the garage/carport). And I do keep it compressed over night, I never drain it, so it never has to start from completely empty. I do purge some air out of the bottom with an electrically operated valve to drain the water out every time I start and finish working for the day.
Thoughts?
Thoughts?
