EMT use outdoors
larry_g
oregon
I need to add a lamp to the stairs on our deck and also would like install a couple of outlet boxes for whatever. Can I use EMT fastened along the underside of the deck structure to carry wiring? I have the EMT on hand but would have to buy sealtite or pvc if that is what is required.
Thanks in advance.
lg
no neat sig line
walrus
Maine
Thanks in advance.
lg
no neat sig line
Yes you can use EMT outdoors
Regular compression fittings outdoors no longer are code( happened in 2005 I think). You need raintight connectors, they have O rings in them. Too bad no one in my area stocks them:headscrat so regular compression connectors get used. I think the state of Maine has said if its a vertical run you have to use them(raintight conns), on a horizontal run you don't.
