Yeah report back. Very curious.
These look like the Genius as said. Genius skips 11mm and duplicates a few sizes; no issue for me. Both are machined out of bar or plate, not forged. Also fine. The only issue is the beam edges are not rounded- not comfortable to use, unless maybe you're wearing leather gloves. The Genius have held up perfectly, no issues, so these should be the same.
Edit: another to consider is the Tone M05 series on Amazon.jp; these have more comfy beams
Okay, I think I get what you're saying. If you work primarily on, say, Japanese cars, the 12/14 pairing makes sense. In fact, fewer wrenches to purchase, perhaps. But for someone like me who may see any size fastener on anything (car, tractor, fire engine, etc) from anywhere, those pairings aren't as critical.
I love learnin' stuff on GJ though!
Edit: typing while you posted above.
The odd size pairings are an oversight imho. If someone designed these for automotive use, they haven’t worked on a car. I would never use both sides of the 12-13 combo on one car, but I would use the 13-15. It’s not the end of the world since I’ll only use these for sneaking into tight spaces where I need that zero angle.
Seems like it huh? It's an issue pretty much industry wide. Even the venerable S-o doesn't get it right, and they're supposed to be the king of automotive mechanics tools...
https://shop.snapon.com/product/Standard-Handle%2C-0%C2%B0-Offset%2C-mm/6-pc-Metric-12-Point-Flank-Drive-High-Performance-Standard-Handle-0%26deg%3B-Offset-Box-Wrench-Set-(10-20-mm)/XDHFM606
Koon Trucking on youtube does a pretty good review of these compared to his Snap On set. He owns a set of both and gives Capri a very positive review.
Here are a few shots of these Capri wrenches compared to the Mountain long pattern ratcheting wrenches (also sold under various brands like EZ Red, Platinum, etc.). The business end is 13mm, a size I use often. The Mountain is 13-15mm and the Capri is 12-13mm. The difference in length is about 3”. The mountain is a little under 16”, the Capri is 13” and a Stahlwille series 14 is 7.5” for comparison. The extra length (mountain vs. Capri) isn’t meaningful to me since should be able to get more than enough leverage on either. The business end is about 30% thinner and the outer diameter is probably 1/8” thinner or slightly more. The Capri outer diameter is a hair smaller than the black ratcheting insert in the mountain wrench. The Capri outer diameter is roughly the same as my other standard non ratcheting wrenches.
Any update on the capri's?Unfortunately it may be a while before I put them to use. The next 60F weekend may be a few months off and I'm only a DIYer, so it's not like I'll use them daily.
The site says these have SmartKrome....kinda seems like they ripped off the marketing of some other company with initials identical to the snazzy word itself, eh?
Worked fine squeezing behind the fan housing to change an idler pulley, no complaints. It does appear Eastwood is selling the same set under their own brand for half the price ($55 plus shipping). Someone on GJ confirmed its Taiwan made, so likely from the same OEM.
https://www.eastwood.com/eastwood-5-piece-extra-long-double-box-end-metric-wrench-set.html
Maybe yes, maybe no. The Eastwood set uses laser etched size and brand markings which suggest a more generic Taiwan maker or could have been an option to reduce costs. The sides of the Eastwood version seems more rounded than the Capri's.
If you look on Amazon at all of the strangely named extra long wrenches and ratcheting wrenches, they're similar to each other but not exactly the same.
I bought an extra long zero offset metric boxed end wrench set years ago from the JTC Tools (another Taiwan made brand, large ebay presence & they have a tool truck in Atlanta area) AAPEX booth for like $50 and they have served me well for over 10 years![]()
I wish someone would make these XL box wrenches with a flex ratchet head, 12 or maybe 6 pt. I have the Gearwrench version, but by the time the "spline drive" engages, you have swung the wrench for 10°, completely eliminating the purpose of the high tooth count.
EDIT: Tekton, Capri, where are you guys???![]()
