Automotive smoke under $150
SuzukiGS750EZ
Hey guys. Looking for a smoke machine under $150. I found the stinger 2 pro for $145. Is this my best option?
Sent from my SM-G965U1 using Tapatalk
SuzukiGS750EZ
Is this for pro work or just for your home garage? Jim
I'll be using it at home, but work on cars in the warmer months for people. It won't be getting used weekly but I have had a use for it in the past.
2ndGearRubber
Pittsburgh
If you're doing EVAP work you will need a flow gauge to confirm there is no leakage after sealing the system. Lots of leaks I find with soapy water since the smoke isn't visible.
SuzukiGS750EZ
I tried this with simple green, can't find anything.
toplessHO
central florida
make your own
pbon
Autool 206 on sale. Pressure gauge but no flow meter. You can make your own smoke for even less.
ChrisLS8
I've always just built a PVC cap with a ball valve to pressurize to 10-15lbs. I have always used this on my turbo cars to pinpoint leaks which can be prone with intercooler piping
SuzukiGS750EZ
I bought the stinger pro 2 this morning. I'll see what I can accomplish with it I guess.
pbon
Can you link to said sale please?
Sorry, for $150 on sale you should be patient and look for the STD 202 - mine was $138. The STD 206 has the flow meter as well as the pressure gauge and will be more.
SuzukiGS750EZ
I'll let you all know how it works. Just got my wisdom teeth out so it'll be a few days at least.
SuzukiGS750EZ
What oil do you use? It says USP on the website. Isn't that just any medical grade oil?
Odd-job
Bought the same one. It does its job and creates a lot of smoke. Running mineral oil in mine. This puts out way more smoke than a cheap cigar from 7-Eleven. Glad I bought.
Thinking of rigging it up to an m12 battery because all of my cars seem to have the battery in the trunks and I am too lazy to run the cord back there plus deal with taking everything out of the trunk.
Anyone know the chances of blowing one self up with one of these? Notice there is a recommendation on some of these smoke testers to run an inert gas through them like carbon dioxide rather than running compressed air.
SuzukiGS750EZ
Well... I haven't even opened the box lol. The mineral oil will be here tomorrow (stores were expensive) so I'll probably get to it Wednesday.
fordnut85
The chance is there since you are oxygenating the fuel vapors in the tank. I would stick with nitrogen to be safe.
unslow1
Illinois
Most of my cars also have the battery in the trunk. I use a clip lead to the alternator battery positive to power things up front.
