Show us your welding projects
74cj5
Omaha, Ne
That third hand is awesome! And I love that little south bend lathe.
Could you share some details on the third hand?
ifirefight
home shop
More..
ifirefight
home shop
This is basically what I started with, had no actual “plans” just kinda winged it.. looking at some skeleton hand pictures on the interweb and my own hand.. that’s pretty much what I came up with. Sorry I can’t be more help.
ifirefight
home shop
Latest project I started today. It’s called an infinity table. Still need to finish up the welding , grind the welds down and slap some paint on her. Will be going with a glass top...I think a wood top would take away from it..
Cheers.
shortykorte
Tallahassee, Fl
Both end tables are awesome. Wife wants to know when I’ll start on hers.
Shorty Korte
Always remember quality in QST
sqznby
Coastal NC
Cheers.
Nice to see someone else make one:thumbup:
Here's my infinity cube
tlevan03
Chesapeake, VA
I made an infinity cube table a few months back. Fun projectfec0f49e744e2d149da3921e4fea3864.jpg
Magneto
"Relocated from VT to Middle TN"
Cheers.
AWESOME Job! Did you wing the measurements or did you go off of plans? I would love to know the measurements. This size looks perfect.
sqznby
Coastal NC
I based mine off of a coffee tables dimensions. It is 18"h x 24"w x 24"l
It can be used in two different orientations if desired, as a coffee table or flip it over on it's side as an end table.
barlowrs
Orange County, Ca
My tool storage space it VERY tight, so I had to get creative for a table saw and miter saw stand. I drew up a stand that has wings that fold out for use and fold down to be stored under my current bench. It allows me to wheel it out to the driveway for use.
80 ft of square tubing and some piano hinge cut and welded up, then table tops made made out of MDF laminated with black Formica and a birch plywood backing to give good bite for the T Track and Miter Track. Edge banded with Walnut. Each table is adjustable to allow me to line it up exactly with the saw cut planes.
I still need to add T rack to the side wings for stop blocks for the Miter saw and Miter track to the rear out feed table to allow table saw jigs to run through.
Also working a router table that sits on top.
shortykorte
Tallahassee, Fl
Now that’s a great saw combo setup. I’ve seen similar in wood but the steel will have more strength and durability.
Also, is the garage floor painted?
Shorty Korte
sqznby
Coastal NC
I'll take one:bounce:
Awesome job man, that is just awesome :beer:
LXCam
Awesome job barlow and one hell of a first post. Welcome aboard, you’re gonna fit right in here.
HotWire
Montana
Custom railings for a friend’s flip.
tlevan03
Chesapeake, VA
I made a set of legs for a slap of black walnut. cb0c5bb96b180dbc51bdeb2f659d1fce.jpg
barlowrs
Orange County, Ca
Thanks everyone it was my first real welding project and first time using mig. I am happy how it turned out. It was a steep learning curve to make sure it was all square and strait, esp without a proper heavy duty welding table to keep things flat against.
No, the back of the garage is a gym that is lined with 1/4 rubber mat, then various rubber depending on if it's the lifting platform or ground work area.
Under the motorcycles is just the cheap-o harbor freight foam tiles.
VERY nicely designed. I like it. How is each table adjusted? I can’t make it out from the pictures.
On each of the fold out supports there is an adjustable "foot" that threads into the support and has a jamb nut to lock it in place. This foot then interfaces and locks into a receiving spot on the fold out wings/table tops. This allows me to adjust them for flatness with respect to the saws. I also made it so I could shim the saws if need be to raise their overall height, but I actually got it spot on, so wasn't needed. See pics attached.
Nice barlowrs.
You almost have more **** in your garage than me........:shocking:
haha yeah, my gf is a personal trainer, so she NEEDS a full gym to teach out of, so I got delegated to half (actually less than half) of the garage for all my woodworking, metal working, and automotive/motorcycle gear...it makes for creative solutions. Most of my stuff is on various french cleat shelving I have made. It's like tetris.
mv213
Dallas, OR (the OTHER "Big D")
That is a sweet saw and router setup!!!!!
Bob Heine
Boca Raton, Florida
Barlowrs, I admire people who fit ten pounds of their stuff in a five pound space but you're closer to twenty pounds in a twp pound space. Well done! :bowdown::bowdown:
wrenchguy
NW Indiana
Made this. The second one I made, and last. Side tables for the sofa, totally functional. WAY over engineered, only needs to hold my beer..
Could be easy adapted to a keg lifter for geezer gathering! Only needs some kind cradle. Nice!
Dureault_s
Foot pedal holder for the side of my tig, need more practice on the machine but not terrible 86480bf794fec66c0c5dd1ae871539a3.jpg
