i have the matco fixed end/flexhead 10-19mm set and love it.
Do you guys use these to break the fasteners loose as well or do you use a non-ratcheting box end and then switch to the ratcheting? I realize you would not use them to break loose a rusted fastener or the like, but I'm wondering if these ratcheting wrenches are stout enough to break loose the majority of fasteners you run across?
Thanks
Thanks
Anyone know the part no. of this set,I've been looking for this?
They are nice an LONG here's a pic next to an 18mm C-man pro for scale
SRFBZXLM102T lists for $409.70![]()
This set is on sale till April 11th for $335.95
). That is 130 cheaper and you get an 8 mm which is much more common than an 11mm. This set number is SRFBXLM52T.Backtracker,
How is the blue Ti finish on the Craftsman wrench holding up?
IMO the nonreversible version that doesn't have the small 'extension' away from the face of the wrench isn't near as useful.
Found this set on the bay,as i look at it more they should've made both ends flexible.
http://cgi.ebay.com/ebaymotors/NEW-...Z380217609971QQptZMotorsQ5fAutomotiveQ5fTools
Fedwrench, being a tech, have you noticed any floppyness yet?
I've done initial loosening of transmission/engine mounting bolts with a 17mm without any problem.
Few things I've noted:
-the beams (I think they are the same thickness as the "SK") are a little too thin.
-when i apply torque on the beam (for initial loosening), I can see the hinged box flexing a bit. I wonder how many cycles it can take before the head starts becoming floppy.
-the reversing button can be a nuissance in tight quarters. In such situations you just have to me mindful when swinging back and forth.
Dave, I bought my 6-pc, metric E-Z RED (EZRRM6) from Tooltopia for $120.
The only company that I know that offers it in a 12pt style is "KTC".
I'm going to bump this up from the dusty archives and ask if anybody knows is SK is still making the deep socket style of these? I couldn't find them on their webpage.
Looks like the EZ Red's have been dropped as well.
Looks like the "Platinum" is made by ATD?
