kr-557 removing front chrome trim instructions?
scotte
hi i bought a kr-557 last week and i'm taking it apart to redo/repaint it
how do you take the front chrome trim (on the sides) off? i have allready taken tare of the little rivets on the bottom but they won't budge
sonexer
Detroit, Michigan
I will be doing the same soon, so I am interested too.
I was thinking of using hard plastic or nylon pry tools and a hammer and tap the trim off. I don't know if this is the best technique, but it is the best I could come up with.
mrshaun
Killeen - Fort Hood
we have a tool that crimps them to the front. I have never tried to remove the trim. usually the guys scuff the trim to give it the brushed look..... sorry I am not much help on this.
mrshaun
Killeen - Fort Hood
sorry didnt read that very well. most trim is riveted on the newer boxes, cant help you on that one.
here is a parts list off of the kr557b model
557AK1400ATR 3 Drawer, Shallow
– 8-1257 6 Offset Runner, Std. Duty (Drs. 1,2)
– 8-1658 6 Channel Track, False Side (Drawers 1-3)
4-6 557AK15A 3 Drawer Assembly
7 557BK2500ATR 1 Drawer, Deep
– 8-267 8 Offset Runner HD (Dr. 6)
– 557K3700A 1 Lock Rod Assembly
– 558K6303 1 Trim Channel (Right) discontinued so be careful
– 8-7739 2 Caster, 5" Swivel w/Brake
– 8-7639 2 Caster, 5" Rigid
– 557K9010A 1 Caster Mounting Hardware Package
– 1-467 1 Spring (Locking Mechanism)
– 8-4937-1 1 Cam (Lock)
– 791X5000 1 Hardware Package
– KN450ASV 1 Nameplate
rsanter
visalia ca
you have to slide it off the end
its a pain to do without damaging
get wood, aluminum, or other soft material and put a slot in it
put it on the end and keep beating on it till it comes off
bob
Stick Figure
Omaha, Ne
i beat up the trim on my 537 top box pretty good trying to get it off. I'm almost thinking its not going back on at this point.
selohssa
Edmonton Alberta Canada
I did that on my box
http://www.garagejournal.com/forum/showthread.php?t=51252
The trim has a fold on the inside lip that fits into a step in the box. Take a pick and pry the inside lip towards the center of the box, just a 16th of an inch should do. Leave that pick in there and take another one and slide it along the inside edge until the trim is off of that ledge. If that does not work, tap the trim from one end to slide it off. The second method works but has a much greater chance of damaging the trim.
I hope that it makes sense, I did not take pics as I was doing that on my box.
Stick Figure
Omaha, Ne
real question is how do you reinstall the trim with out scratching the paint? That's what really has me considering leaving it off.
Vinko
Los Angeles
Shaun: do you know about the drawer trim for the 557? Is it still available?
I just found out that the drawer trim for the long drawers on the 537 is still available, but not for the small drawers.
What's the hardware package? The fasteners?
I assume channel track is self-explanatory. It's good that this is available because I can straighten one of the channels and that's impeding the first drawer.
Stick Figure
Omaha, Ne
Putting it on is super easy. Line it up in the position that it needs to be and push it on. Make sure that the lip of the trim clicks into the slot on the box.
but does it scrape up the paint on the way on? and what about something thicker like if i decide to powder coat it?
selohssa
Powder coating will be very strong, it should not damage that. If you use a soft primer surfacer, it may scratch but only if you have irregularities in the stainless that cause one part to dig in to the paint.
