what are these used for??
rsanter
visalia ca
I picked these up at a pawn shop
I looked up the tripple square snap ons
ftsm8c and ftsm6.
it indicates these are used on european, but I would like to know what european cars and where?
the next one is a mac SC86
I could not find this on the MAC website
you guys have any idea?
View media item 4009
bob
fordbroncodave
i think they use those for the front axle shafts on a VW cars. they are used for the 6 bolts that bolt the cv axle and the transmission together. i usually have to use a 24" extension and a 3/8" impact to get those out
Goinlow
Yup I just did a clutch on my jetta and to take the axles out there was 6 triple square bolts. I believe my doors are held on by those bolts also.
ears
lorton VA
The MAC sc86 is for VW light switch and windshield wiper switch. "Late model" according to a 1973 catalog.
6 MM triple square is for VW disc brake calipers and CV joints
8MM triple square is (obviously) for Opel manifolds.
These are listed as FSTM6A and 8B in my catalog.
Hi_Psi
def european. i had to do a clutch on a mercedez benz diesel truck and flywheel bolts were 12 point inverted
R
rsanter
visalia ca
ok
well that helps a bit
I have a mercedes so I guess I will keep them just in case
I have a spare 8mm ftsm8c so I guess I can sell that one and I dont think I will need the VW switvh socket
bob
nolatoolguy
Louisiana
Those first 2 tripple squares are used in some the windrowwer rakes we have. Those are the type of bolts that hold the rake wheels on.
As far as the other I have no idea, my best guess is there was spose to be a alen in it and it fell out over time, i have no idea on that one man
visitam
Some toyota head bolts use triple squares. I know for a fact that the 2ZZ-GE from lotus elise/exige, 00-05 celicas and such use 10mm triple square for head bolts. Otherwise, used mostly for vw's and mercedes
kwhitelaw
ok
bob
might be interested in that 8mm if you sell it...pm me a price and ill see if I need it.
thanks
Stick Figure
Omaha, Ne
Sorry they are technically NOT triple square. They are what is called a double hex. Yes they are both 12 point, but like Torx and torx plus they have slightly different shape and the Triple square can round out a double hex bolt.
example:
http://buy1.snapon.com/catalog/item...group_ID=20984&store=snapon-store&dir=catalog
as far as the triple square VW head bolts are also triple square on some engines if my memory serves me.
visitam
example:
OMG I can't believe that is true. Apparently I removed my head bolts with a triple square the other day, thinking it was the same thing. Good thing I haven't installed the new ones yet! Putting these on order right now!
daveblank
Dallas, Texas
Since no one has hit on the Mac socket yet, it's a pronged socket. The most popular use is for the retaining nut on power antenna masts. I sell tons of them to our bus company. They use them on the bolts for the inside light panels.
Stick Figure
Omaha, Ne
Its okay i didn't know it until i came across a really stuck bolt that rounded out rather than coming loose. When i asked my Snap-on rep about it he told me about the double hex.
mrshaun
Killeen - Fort Hood
vw and audi are the main cars that use the triple square or double hex. some head bolts are this style for toyota and a few others some vw head bolts are actually poly drive.
door hinge bolts on a couple of cars use the double hex/triple square.they both equal 12
srmofo
SW ohio
so its says that a triple square will strip a double hex. Will a double hex strip a triple square?
