All,
I have a post that supports our wrap around deck that is out of plumb by a 1/4" in one direction and approx 1/8" in the other direction. The other major issue is the lack of connection at the base.
Background: House is 16 years old, we are the third owners, and we are situated in middle TN.
In the attached pictures you can see where I recently replaced a garage door into the basement (must be a southern thing) with a properly build wall. The span there is 16' from the post in question to the right side. There are five 2x12's supporting this span. On the left side of the picture the span between posts is 8' with two 2x12's forming the beam.
Unfortunately when they connected the support posts to the beams they toe nailed and faced nailed everything together instead of notching the tops of the posts.
I'm thinking that I could add another 6"x6" post in the middle of the 16' span, properly anchored at the top and bottom for additional support.
As for the out of plumb post, I'm thinking of sistering a 2x6 to each side, anchoring them to the slab and using proper brackets at the top.
Removing and replacing this post seems like a big job given the way it's connected at the moment. I'm aware that there are joist hangers that should have been used too, I will address that as well.
The beam is level and there is no sign of sagging.
So what are the thoughts on this idea?
Thanks,
Lou
Thanks,
Lou
