Fluid for the parts washer
javie
Missouri
Hello, I picked up a really nice parts washer at an estate sale and intend to use it in degreasing/cleaning up old drill presses, vintage electric motors, etc... I'd like to hear from folks about what are some good options for fluid to use in it for those purposes. Suggestions from experience?
XJSuperman
Central Iowa
engineer2
Chicago burbs
Mineral spirits is about $8/gal. Try to get the odorless kind (sometimes called odorless paint thinner).
Some people like Simple Green.
Some simply buy 1K (or K1) kerosene.
Of course, never use gasoline!
lis2323
I’ve used stoddard solvent in mine since the 1980’s. It works well and I like the smell.
I added a filter to mine to extend cleaning life.
K'ledgeBldr
Johns Creek, GA
Odorless mineral spirits is like $8/qt- not a gal.
Always check the pump in a parts washer- some are made for water-based solvents/cleaners. Older cleaners were usually made for petroleum-based cleaners.
57plymouth
I use mineral spirits. I found that it was cheapest from Wal Mart of all places. The water based stuff did not work to cut greasy crud when I tried it, plus it smells like dirty diapers.
J
javie
Missouri
Thanks for the great info folks, it is much appreciated. There is a Tractor Supply right down the road and it looks from the reviews on TSC's website like it is low/no odor for a great price.
mslim
Fayetteville, AR
gearhead1
NC
I’ve always used mineral spirits too. It cuts oil, grease, and leaves a very slight film for a little bit of rust protection. I’ll use acetone on the part if I’m going to paint it. Minerals spirits can be found anywhere and flash point is higher than something like gasoline.
SGKent
Citrus Heights CA
White spirits, Mineral spirits, and Stoddard solvent are essentially one in the same. It will burn and it will flash but much higher than gasoline. Keep the unit in a place away from sparks and open flames. I use it in my Safety Kleen parts washer. Late model parts washers sold el cheapo for water based solvents do not have the proper pumps or fire triggered lids.
MileHighRover
What is everyone's opinion of purple power
Sent from my SM-A102U using Tapatalk
Purple Power is weak. The best water-based degreaser I've ever used, and I've been using it for two decades now, is Super Clean degreaser. I've never found it cheaper than Walmart - $9 a gallon. Not for use on aluminum, though.
Jagmandave
Overland Park, Ks.
I've used the stuff from Tractor Supply too and it works just fine, but my first choice is Crystal Clear (Clean?), they're like Safety Kleen, but much less expensive......I paid $167 delivered for 25 gal and they took away the old solvent....that's the best part.
SK wanted $426 delivered!
I found them online and just called, they came out the next day - I'm about due to have it replaced again.
fsae0607
San Fernando Valley, CA
PSC1000 and mineral spirits in mine.
I had a five gallon washer with mineral spirits and upgraded recently to a 20 gallon. Filled it with PSC1000 and poured the mineral spirits into it. Works great!
Shadowdog500
Down the shore
Is it a metal parts washer or a plastic parts washer?
For a metal parts washer I’d definitely use the PSC-1000 from tractor supply. (I use this in mine)
For a plastic parts washer you may want to look at a water based cleaner.
I doubt you picked up a special parts washer like an ozzyjuice one that has a heater.
Do you have a picture of the parts washer?
bullnerd
Jersey
I lost my original parts washer in a fire, So i bought some of the cleaner from TSC just to use out of the can.
IMO, it does not work as good as plain old OMS.
I had to clean some casters from a used engine hoist. It would not cut the grease like OMS would have.
Lou's Garage
Anderson, SC
Whichever solvent you decide on, here's some advice that's worked for me. Simply put, don't fill your machine. For example, I have an old commercial unit that holds 7 gallons and I've found that I can get by on about 2. When it evaporates enough to reduce the flow, I add more. The solvent lasts a long time under these conditions and debris seems to settle out better. When it is time for a change, there is not as much used fluid to dispose and the debris just scrapes up off the bottom.
Lou
bdk1976
I use solvents from garage/estate sales - pretty sure I have a mix of mineral spirits and kerosene in there now. You can generally gets gal cans of various “fullness” for anywhere from free to $1-2 around here.
J
javie
Missouri
Sorry, I do not have a picture, but it is this one:
"https://www.grainger.com/product/GRAYMILLS-Parts-Washer-4KTW7"
J
javie
Missouri
Lou
Thanks for the advice. The unit does say it'll operate fine with like half the capacity, too, so I'll definitely try that Lou.
Shadowdog500
Down the shore
That parts washer uses regular solvent. Use the psc1000 from tractor supply.
If you put water based cleaners in it it will start to rust out.
I use psc 1000 and keep the lid closed on my solvent tank and haven't had any issues with evaporation.
pancho400cid
Austin, TX
PSC 1000 in mine. I put 10 gallons in 4 years ago (not cheap). No noticeable drop in level. I do make sure to close the lid. Not "amazing" but "okay". It does not seem to have the same bite as Varsol from days gone by but I think it is less toxic/carcinogenic.
I guess I would consider water-based solvent IF my parts washer was plastic, but the guy who owned my metal 30 gallon before me had water-based solvent in it, which lifted the paint and caused some rust pits.
damon18
Memphis, TN
After way overthinking this for a while I bought a small benchtop parts washer from Jegs, they were offering a package deal with two gallons of their degreaser.
https://www.jegs.com/i/JEGS/555/72302/10002/-1
I was a skeptical because of all the scoffing I read about water based degreaser.
But it works well for me, I'm pretty impressed and have also used ot diluted in a spray bottle.
Sent from my SM-G973U using The Garage Journal mobile app
BillK
Beautiful Southern Maryland
The biggest issue with parts washer solvents is getting rid of the dirty stuff. Thats why Safety Kleen or Crystal Clean makes sense like Jagman said. I wonder if the Safety Kleen guy did not understand what he was looking for though because they are both about the same price around here.
Metallitubby
ATL OTP North
At the risk of sounding like a spammer or bot (which I'm not mind-you), our race team is sponsored by GTech Cleaner.
1. It's water-based.
2. It's safe.
3. It isn't a solvent.
4. It can be filtered (we use coffee filters once a month)
5. Yes, it's expensive but it works.
