Safety of Jack Stands
WES51
California
I have always been wondering about the safety of these things, particularly the tripod style notched center column for the height adjustment type, with height being adjusted using a simple ratcheting lever. Or in other words a simple regular jack stand.
Provided of course that the correct weight/load rating IS used and NOT exceeded, how safe do you guys feel about these?
Would you feel safe with a car standing on 4x of these, 1x at each corner? Or would you use 6x just in case?
What are your thoughts and experiences.
Lou's Garage
Anderson, SC
Throughout the late 60's, 70's, and most of the 80's I worked on cars daily, for a living. Lifts were not nearly as prevalent then so we did a lot of work on jack stands. We never had a problem with a jack stand as long as it was correctly spotted under the car (or truck) on even, stable, solid ground and not overloaded. I can't list all the "what if's" without missing at least one but I would be reluctant to use stands on blacktop on a hot day. It is likely they will sink in.
Lou
Jhoff310
Perrysburg Ohio
As long as you follow their weight ratings, I wouldn't have a problem. I also use 4x4 cribbing just for extra measure. Years ago My uncle Joe was killed by a failed jackstand.
BillK
Beautiful Southern Maryland
Wes,
As I get older I feel less comfortable with them but still use them. I remember doing clutches and transmissions in my Chevelle with all four corners up as high as the stands would go. Not sure if I would do that now. I will say that I think some of the older heavy duty stands seem a lot sturdier than some of the new stuff I have seen. The ones I have are probably 50 years old.
Bluedodge
Michigan (not the Detroit part)
UNSAFE....
In the 80's, the parts store sold a **** load of these tri-pod stands:
Their stability was at the mercy of six chintzy tack welds at the bottom. It is my understanding they're unacceptable by OSHA and are no longer permitted in shops or to be sold in the US.
If you have any of these, please do yourself a favor and get rid of these widow makers.
Jagmandave
Overland Park, Ks.
I still have a set of those and I use them all the time - just not to hold a car up! They're great for supporting an exhaust system while you weld it or to support a subframe while I bolt parts to it before I put it in the car or any number of such tasks....I just don't lie on the ground under a car supported by them. So, no reason to throw away a good tool, just use it appropriately......
W
WES51
California
Well, that is kind of where I am now.
I have 4x 6 ton Heiner Werner jack stands for my 1500 GM truck and think about buying 2x more, but storage is an issue in my 'little' garage. I'm running out of space to put things.
I have 2x more of tbe shorter 3 ton Heiner Werner jack stands as well, as well as 2x more small ones to place under parts as support.
Bondo
Greenfield, Maine
Ayuh,..... Yer truck weighs nowhere near 24 tons,.....
I have much more faith in the rachetin' jack-stands than the flimsy tube ones,....
lilredex
Toronto
Was never a fan of those tripods or ratcheting types of stands. So in the early eighties I made a set I was comfortable with.
Recently saw some hydraulic types that would be good for newer vehicles with jack points only.
txvwnut
Bedford, Texas
UNSAFE....
My brother murdered many of those sheetmetal stands back in the day.
ericlar80
California
I have a set of these for holding up whatever I work on. They are very stable and I like them for the through-pin.
https://www.jbtools.com/esco-equipment-10498k-3-ton-performance-jack-stand-kit
I can't bring myself to trust the ratcheting style jack stands with their brittle cast iron posts, and chintzy ratchet mechanism, and loose tolerances. Through pins and solid steel can't be beat (in my opinion).
BTW - if you don't require the rubber pad on top, I would suggest these ones:
https://www.northerntool.com/shop/tools/product_200610848_200610848
finn
The UP, God's country
The sheet metal tube stands are dangerous. They collapse easily and dig into the ground and tip if the ground isn’t solid. I still use mine, but only to hold a trailer tongue or perhaps a rear axle, not attached to the car.
The small two or three ton stands with the ratchet height adjustment locks are a little better, but I rarely use them. The larger six ton stands have a larger base and are much more stable, plus are taller, so that’s what I use and recommend.
Some of the small aluminum stands that are sometimes packaged with the light weight aluminum jacks look sketchy, at best.
Killer95Stang
Used them all the time, but I was always taught to stick the wheels under the sides or leave the floor Jack pumped up under the lifting point. I now mainly use my quickjack for convenience, will stick a Jack stand or a wheel under the car just in case.
Bretny
Dutchess county NY
I made a set too. They go up to 48in high. I had a lifted truck with a 2in tube bumper.
Jeepster04
I've got the 6 ton (per pair) craftsman jack stands and use them anytime I'll be under the vehicle. Otherwise I use the small 2 ton craftsman jack stands for brake jobs/tire rotations or whatever.
I dont feel a bit nervous using the 6 ton jack stands at max height on flat ground. When I spray fluid film/wool wax under my vehicles I get them up to max height. Im certain 1 of them would hold my vehicle so Im confident Ill never have any issues using 4 unless I do something stupid.
I would steer way clear of those tripods....
driz
Northern NY
That’s me since the 70s. I don’t trust nothin or nobody always a backup. Only once did I have a car fall off a jack or stand . It was a cheapo Walmart short jack. The one that is quite narrow stance. It got a sideways lean going and finally flipped sideways. Even then it stayed put far longer than you’d expect.
Those sheet metal stands really do a job on an asphalt driveway too. Close behind is all the trolly jacks today. Those wheels leave nice dents on a hot summer day. I keep some pieces of steel plate handy to put under the front of the jack and those [emoji90] jackstands
NETexas
Attached
Same here!
Sent from my iPad using Garage Journal
DFB
Southern VT/Western Mass
Omg those tube style flate brace with pins are **** for sure. :D
I have a an old, old set od them I use for small lightweight stuff only. Mostly for motorcycle support.
Same with a set of little ratchet ones Craftsmans and they are and actually not much to write home about for either. I kept them as part of a package deal after I sent back their tweaked floor jack that wobbled and wouldnt sit right on the concrete floor
Yup get yourself some of the 6 ton...for added height too
I have 2 sets.
If your only doing one corner at a time the smaller ones will do though.
No matter what solid ground support underneath is essential.
Tire and rim under axle...good security :thumbup:
Cripes I even bent up a set car ramps once on gravel when they sunk in :eyecrazy
Jazz1
Thunder Bay On.
I use 6 ton jack stands and still set a block of wood under the vehicle. New stands have a warning on them not to go under vehicle when on stands.
robinsoc
Ottawa, ON
We use them all the time at work for full size school buses. Never an issue as long as they are in the appropriate position and have the correct weight rating for what you are supporting.
RossABQ
NM
I learned on here some time ago, jack stands' ratings are for a pair, not per stand. 4 x 6-tons rating = 12 tons capacity (if evenly distributed).
I used to worry about the ratchet style, not knowing whether they were cast iron (brittle), malleable iron (much less brittle), or forged steel. Someone on Reddit posted a picture of one that broke, it was clearly cast iron. Chinese cast iron, of course. I set the load down on mine very slowly.
driz
Northern NY
Luckily now you can but something way beefier and totally adjustable for around $200 a set (2). 10 ton ea.
Notice that there’s that nice little touch with those . Actual feet to spread the Weight around and reinforce the base of the legs. Nice touch. Also notice the simple pin height settings, cheap but simple . No way it’s going to cam off a not completely engaged or worn tooth.
Like the old Sarge always said, “ Keep it simple stupid”. Hell if I have to get right under there for something rough I’ll set it on wooden 8 x 8 or 12 x 12 blocking. If it’s gotta go really high it gets a pair of 12-14” tree trunk sections with a steel cross member between them . That’s as solid as a rock .
Give me a lift any day though and my soon to be next garage is going to get one!
wssix99
Chicago, IL
As long as the footprint of the jackstands is equivalent to the contact patch of the tires (most are for cars), 4 in the corners is going to be really stable - just like the car sitting on it's tires.
If these footprints are equivalent and you aren't doing anything weird (lifting areas of the car, torquing the whole thing, etc.), things will be just lovely.
That being said, some jack stands also have other safety feature like bolt or slide locks that hold the ratcheting part in more securely and permanently.
CraigStu
Blacksburg, Va
JRC3
Southwestern OH
619DioFan
San Diego , Ca.
You guys ever seen anyone use cinder blocks? :shocking:
As a teenager I grew up next door to a retired navy captain. he would use a brick , a piece of 4x4 and a piece of firewood stacked up as a jackstand. then sit with his legs under the car while yanking on things. amazed he was never squashed.
619DioFan
San Diego , Ca.
I use the HF 6 ton stands with my 95 dodge ram 2500 4x4. I have had the whole truck off the ground on 4 of them with no worries. I have 2 HF floor jacks and always have one under each end as well.
Farmall450
Marengo, Illinois
I use good 6 ton (Snap-on/HW, US Jack, and now I added a set of AC Delco (imports but nicely made). No worries by me, they're well made.
Leaflessshadetree
Don't ask.
Back in the 80s I was using oak cribbing, like used by fire departments/rescue workers. Someone thought my cribbing wasn't safe and gave me a set of those sheet metal stands. I don't recall if I ever used them succesfully but sure do remember hearing/seeing them began to fold as I moved out from under the car.
I haven't had any problems with the ratchet style stands.
Bighead38
Rockland County NY
Since I work on everything in the driveway I always use jack stands. I put wood under them so they can’t dig into the blacktop. I’ve done everything you can to a car on jack stands, motors, transmissions, rear ends, suspension, brakes, etc.
