2ndGearRubber
Looking for a higher tooth count 3/8 drive torque wrench, 10-100lb standard range.
My family of torque wrenches are all USA made gear-wrench, back from the Husky/Gearwrench/Matco collaboration. Issue being; they're all 30 or 36 tooth, which really gave me issue torquing some obscured torque converter bolts today. Unless I can find a drop in kit to upgrade the tooth count (which I doubt), it's time to add another member to the family.
So, my first check was Snap on, a used tech-angle is $200+, things are $500+ new. I'm also unsure about buying a used torquing product. I like the idea of having angle, not so much the idea of batteries though. Are the tech wrench/tech angle family reliable?
I looked at CDI and PI, but saw no tooth count listings. The shop split-beam PI is pretty low tooth count.
I also saw gear-wrench has released a 120XP torque wrench, but the handle looks freaking huge. All my wrenches fit in a 2" deep drawer currently, and smaller/slimmer is always better IMO. It's also around 200 if you want angle, otherwise I'm not really interested in electronics.
Also, is there a limit on angle vs. torque? Like torquing flywheel bolts to 50ft/lbs + 90*, but the effective torque of that action is 105ft/lbs, and the wrench is only rated for 100. Will it just give up on me and refuse to torque? Has anyone used the clamp on attachments like brownline or summit?
So what should I be looking at? I'm all for buying once, but any money I save on this tool can be put towards others.
