ddawg16
I'm making a lifting jig for some modules that weigh about 100 lbs.
The best way to describe what is looks like is the grabber used to pick up blocks of ice.
In this case, the module has a groove along the side....so my grabber has these tabs to fit in the slot. There will be 2 grabbers, one at each end of the module...so 4 feet...each one carrying around 25 lbs.
I'm thinking I can just mig weld the bottom...let the tab be a bit proud so I have cavity...then just flood the cavity with Mig weld.
Or do the sides on the top. I kinda just want to weld the bottom for a cleaner look. If I had access to a TIG, then I'd weld on top
The steel is 1/8" cold rolled.
