Mountable Power Strip
Bill97Z
I am looking for a powerstrip (4 outlets) to mount on the front of my workbench to plug tools into. Most of the ones I have seen use cheesy mounting brackets or have inset holes in the back. I am looking for one that I can screw into the wood for a sturdy mount. Any suggestions?
Bill97Z
Thanks, I am looking for something simple, readily available, and under 25 dollars
Jack Olsen
Los Angeles
"Stanley 31610 Surge Protector 9-Outlet Power Strip with 6-Foot Cord, Black"
It's 24.99 on Amazon. The package calls it 'Pro-Max 9.'' It's metal, black, and has mounts on either end that you can just run screws through. The strip itself is 37" long and has 9 grounded outlets spaced over it.
Since it's Stanley, I'd bet you could call around and find it locally.
I just got it, because I liked this (longer) one so much on my main bench.
The one in the picture is not a Stanley, though. It's a 'Prime.' But I'd wager they're made at the same factory.
Norcal
It will cost more then $25.00 but google "Plugmold" , the big box stores sell it.
Handyman163
SW Michigan
The Stanley one on Amazon doesn't have the mounting tabs on the sides. I'm guessing it's only got the recessed ones in the back.
I was looking at these at HF, and noticed the metal used on that one was super soft and flexible. I don't think 2 mounting points (one at each end) would hold it securely enough depending on how tight the outlets were.
Bill97Z
Thanks, some of these look good, but I was hoping it would be less than 24" total and I only need 4 outlets.
Jack Olsen
Los Angeles
The Stanley one I just got has four mounting holes -- two on each end -- and plastic cap pieces to cover them. It also has cross-shaped inset holes in the back for that kind of mounting. You could also undo the screws that hold the carcass together and just put some self-tapping screws through the sheet metal.
Slow Gray Mule
MS Gulf Coast
I have this same Prime 9 outlet in my garage. It has a few mounting options. I picked mine up at Lowe's on sale for around $25. They also had a unit that the case was made from aluminum diamond skid. Looked real nice, too. It was around $35.
Busted_Knuckles
Northwest Illinois
This is USA made by intermatic, its hospital grade, bought on ebay for $25 new in box shipped to my door, has a master switch on the end, and an additional switch for each circuit and is made of the utmost quality, I bought it for my service cart, buy my girlfriend got a hold of it before I got it mounted. Has flanges for permanent mounting.
13 1/2" x 3 3/4" outside dims including flange, is very well made.
I should add this does not provide any circuit protection, but is very well made, if you just need power and not worried about surge, circuit breakers or gcfi's.
From the ebay listing:
http://cgi.ebay.com/Intermatic-Audi...emQQptZLH_DefaultDomain_0?hash=item51918c4fc5
PRODUCT DESCRIPTION:
Audio / Video Hospital Grade PDU Power Strip
This is brand new in its original packaging. The original cost was $368.00 each.
Very nice, extremely well made. Made in U.S.A.
Nice “ON-OFF” switch for each component.
Hospital Grade Connector.
110V / 220V
50Hz / 60Hz
15 Amp
6 Foot Cord.
Original Price $368.00 each!
Rubber Feet.
6 Lbs Each
Boost Creep
michigan
i got one of those and its plenty stable screwed into my bench.
