New Milwaukee M12 Fuel Cordless Right Angle Impact Wrenches
impactsocket
New Milwaukee M12 Right Angle Impact Wrenches
- 4-mode drive control
- Up to 220 ft-lbs of nut-busting torque
- Auto shut-off mode – prevents overtightening in the forward direction
- Bolt removal mode – provides more control after bolt breakaway
https://toolguyd.com/milwaukee-m12-fuel-cordless-right-angle-impact-wrenches-032020/
Video:
Pricing
Milwaukee M12 Fuel 3/8″ right angle impact wrench with friction ring
Kit (2564-22): $299
Bare tool (2564-20): $199
Milwaukee M12 Fuel 1/2″ right angle impact wrench with friction ring
Kit (2565-22): $299
Bare tool (2565-20): $199
Milwaukee M12 Fuel 1/2″ right angle impact wrench with pin detent
Kit (2565P-22): $299
Bare tool (2565P-20): $199
I
impactsocket
A protective boot will also be available, for ~$29. The same SKU 49-16-2564 fits all three tools.
dnschmidt
Phoenix, AZ
I've got mine on order with the boot at Acme Electric. First the M12 right angle die grinder (a work of art) and now this. Milwaukee is on a ROLL!
I
impactsocket
Why would you still need the M12 FUEL 12-Volt Brushless Cordless Ratchet if you purchase the Milwaukee M12 Fuel Cordless Right Angle Impact Wrench?
M12 FUEL 12-Volt Brushless Cordless Ratchet only has 55 ft. lbs. Max torque.
consti2tion
East Texas
That ratchet has a thinner profile, so it would fit into tighter places. That and the ratchet is likely a little easier on stuff when you are using it to tighten nuts/bolts down.
DFB
Southern VT/Western Mass
With the impact your not going to experience that just enough feel a ratchet provides when hand tightening something and so your all dependent on trusting (with the all variables) the tightness on fastener the impact can provide in the range being used.
If its any bit as good as it made out to be there are probably many jobs where it can easily replace the ratchet though.
Overall and just my own opinion here I'm not real big fan of the FUEL ratchet. I have one often I find it bulky and a bit heavy and generally prefer using the older cordless ratchet.
But for some of the work scenarios I'm using the FUEL ratchet I think the new RA impact will be the better tool especially on certain disassembly chores.
I for one will be looking forward to seeing a side by side size comparison on those two cordless tools
M635_Guy
NC
I see the RA Impact and the FUEL ratchet (which I have and love) as very different tools. I have and love the FUEL ratchet, but this new thing would be a competitor for my M12 Stubby. At this point, I haven't really hit a spot where one of these tools isn't working for me.
If I was a pro, I could see a Stubby and the RAI co-existing...
MattT
The Stubby has pretty similar measurements to what ever tool it's compared to in that ToolGuyd advertising chart that's was originally posted... both height and length
They appear to be comping against the IR hammerheads. If you click on the link Skin posted in Post 3 there's some discussion of comps there.
I
impactsocket
The Milwaukee M12 Fuel Cordless Ratchets (55 ft-lbs of torque) are too weak. They are expensive nut runners. I think this is the reason why Milwaukee decided to come out with the M12 Fuel Cordless Right Angle Impact Wrenches.
In addition, the Milwaukee M12 Fuel Stubby Cordless Impacts (250 ft-lbs of torque) are too big and bulky to fit in tight places.
Milwaukee M12 FUEL Right Angle Impact Wrench (220 ft-lbs of torque) can replace both the cordless ratchets and cordless stubby impacts.
Fedwrench
Valley of the sun
Perhaps for you but, not for me. I don't want to use a long handled tool for most of my applications. I really like the stubby impacts. Besides, it's not about replacing existing tools, It's about supplementing existing tools. :beer:
KnurledNut
n/a
Im thinking the trigger design on these is gonna be problematic; more so function than failure.
I
impactsocket
Here is a video of the Harbor Freight Earthquake XT Cordless Ratchet and Milwaukee M12 Fuel Cordless Ratchet struggling to remove a nut torqued to just 40 ft-lbs of torque. The Milwaukee M12 Fuel Cordless Ratchet took 2 pulls of the trigger.
I
impactsocket
Here's a toolguyd.com online article about "Can You Use Milwaukee’s Cordless Ratchets Manually for Final Tightening?"
Link to toolguyd.com online article:
https://toolguyd.com/reader-question-milwaukee-cordless-ratchets-final-tightening/
I asked Milwaukee Tool whether their cordless ratchets can be used manually (unpowered) for final tightening or initial loosening without concerns about damage to the gearing or internal components
Here’s what they said:
We understand people do this but it is not recommended with these products.
So, although you could use the ratchets manually, it’s not recommended.
I
impactsocket
I wish I was getting shill money or a free tool but that is not the case. I have bought into the M12 and M18 lines.
I
impactsocket
You can now see it in action.
Milwaukee M12 Right Angle Impact Wrench video tool reviews:
mc4life27
The point was? I though it was about two tools sharing a place in the tool box not about how you can and can not use a tool.
Regardless not sure if
You have that ability to break loosen the fastener with the right angle impact.
Mr_B
Reading
No because all it really is, is a super stubby impact wrench with long grip .
It not a ratchet ...
DFB
I've always like Workshop Addict videos
And I'm itchin' to buy something...this tool, framing nailer, and extended ratchet are all on my short list
But wow was really feeling completely sold on it until it couldn't remove the 130# lugnut :eyecrazy:
But then did more with a different style nut
Looking forward to and XC battery boost
Really likening the auto mode too :D
Interesting all the variables though.
Agree a heavier socket always helps...good example with the shallow vs the deep. And I have had similar experiences between 1/2" and 3/8" deep sockets same tool same fasteners
Should beat using the ratchets in a lot simple removal chores hand down though and work pretty good in most applications non rusted/seized fasteners under 1/2" (12mm) thread size.
On to the next video Mr Suburu ;)
Is a big unit overall
Mr_B
Reading
indeed it is and that main draw back on most battery tools and the M12 line been fairly decent sized besides the ratchet and this impact .
power to size is piss poor .
Is a great tool and will get better as design and tech keeps improving .
I won't be buying one as limited use to me in a autoshop environment .
I
impactsocket
I can not decide whether to get the 1/2 inch anvil or 3/8 inch anvil version. I don't have the budget to buy both versions. Which version would you recommend?
The 1/2 inch anvil Milwaukee M12 Right Angle Impact Wrench will impact harder than the 3/8 inch anvil version. But 3/8 inch deep impact sockets will fit in tighter spaces.
DFB
I was just thinking about that, and for me it be 3/8" and a low profile adapter to use the heavier 1/2" sockets
I recently purchased a set of those adapters...Titan Brand I think the were. Liking them a lot.
DFB
DFB, can you post a link to the low profile adapter?
Titan 30936
https://www.amazon.com/dp/B01ENX11B6/?tag=atomicindus08-20
Amazon is the best price link I see...and less than ARES which seems to be the same. Can be found other places like on Ebay and National Tool Warehouse also stocks Titan brand products.
For about 2 x the price Grey Pneumatic also offers a set that may be even a tad shorter, :dunno: but these are about 1/2" shorter than standard length impact adapter. Might be some others options too These short adapters have been mentioned before on TGJ
Here's is a pic the 3/8 drive to 1/2" on my Stubby with a 15/16" socket. Worked out great for me removing a riding mower blade nut recently.
RKA
I went with the 1/2" after seeing how poorly the 3/8" did with a shallow socket. My reasoning is I'm more likely to use it on the larger rusted fasteners where feeding an impact gun is difficult. A 1/2" socket should help me squeeze the most out of this one.
I
impactsocket
DFB, thank you for the link to the low profile adapter.
I plan to buy a 3/8 drive metric deep impact socket set (8mm - 19mm) and 3/8 impact extentions.
1. Which brand 3/8 drive metric deep impact socket set do you guys recommend?
2. Does anyone have the Tekton or Milwaukee 3/8 drive metric deep impact socket set?
3. What is a good brand for 3/8 impact extentions?
TEKTON 3/8-Inch Drive Deep Impact Socket Set, Metric, Cr-V, 6-Point, 7 mm - 19 mm, 13-
$25.45
https://www.amazon.com/TEKTON-8-Inch-Impact-Socket-6-Point/dp/B00F9Y1NHQ
TEKTON 4966 3/8-Inch Drive Impact Extension Bar Set, Cr-V, 3-Piece
$10.49
https://www.amazon.com/TEKTON-4966-8-Inch-Extension-3-Piece/dp/B000NW85F2/ref=pd_bxgy_img_3/145-1206015-8735035?_encoding=UTF8&pd_rd_i=B000NW85F2&pd_rd_r=afb6efb0-7eee-4b06-9b01-d5e0861fda2f&pd_rd_w=L2XBu&pd_rd_wg=d5sDV&pf_rd_p=4e3f7fc3-00c8-46a6-a4db-8457e6319578&pf_rd_r=SJSDH634D33RY0YQX5Q5&psc=1&refRID=SJSDH634D33RY0YQX5Q5
Tallpilot
Orlando
$25.45
$10.49
Hard to beat Tekton for price/performance.
I
impactsocket
I have Campfield Hausfeld impact sockets fit loose on bolts while my SK impact sockets fit tighter on bolts.
Does the TEKTON impact sockets fit tight or loose on bolts?
Tallpilot
Orlando
I grabbed an M12 bolt out of my parts bin. I tried it with Tekton, Grey Pneumatic and Astro. They all felt the same. Certainly none felt loose.
I
impactsocket
Tallpilot, Thanks for the feedback on the Tekton sockets.
Does anyone have the TEKTON 4966 3/8-Inch Drive Impact Extension Bar Set? How do they hold up?
Milwaukee M12 3/8 Right Angle Impact and Milwaukee M12 3/8 Stubby Impact = Size comparison video:
https://www.youtube.com/watch?time_continue=328&v=X1hb_RlvgS4&feature=emb_logo
M635_Guy
NC
impactsocket;8579241 [IMG said:
https://news.ohiopowertool.com/wp-content/uploads/2020/03/chart2.jpg[/IMG]
:bounce: They should probably give CP at least a checkmark also for weight considering they're over 3/4lb (~25%) lighter :dunno:
Mr_B
Reading
Yes and not cherry picked comparisons, the better model pneumatic angle impacts not gear driven are in the high 300ft-lb to low 400ft=lb torque rating .
they also less bulk .
I own 2 of them and they useful mainly as torque to size ratio good.
Only reason the waukee got that reach is motor/control and battery made it a necessity and they marketing numbers not ergonomics and real world limitations .
DFB
$25.45
The 13pc Deep Metric Sunex set is Cro-Mo construction and is only like a $1.00 more than Tecton CRV set/
https://www.amazon.com/dp/B0002SR9BI/?tag=atomicindus08-20
To be honest I have HF Pittsburgh impact extensions in 3/8 drive and I have no issues with them, really like the various sizes especially the short one, only $8.00 and can get 20% off too
https://www.harborfreight.com/38-in-drive-impact-extension-set-4-pc-67926.html
