The repurposing thread
sberry
Brethren, Michigan
One of the real valid reasons to buy that stuff is to fix build save. Doesn't take a lot of repair anymore for it to earn it's keep. Salvage is often so much easier and faster not to mention cheaper than starting every piece from scratch with new steel and a trip to the yard.
Honch
Danville, IN
Good thread, I have a few to add.
The feet on my compressor are the upper A-arm bump stops off of early 70's GM cars.
I bought a magnification light at a garage sale for 2.00 but the base was broken. I welded some one inch strap around the cast base and when it cooled off it shrunk to a very tight fit. I used a aftermarket oil cooler bracket to mount it to my workbench, this makes it easy to remove if its in the way.
I repurposed some BMX bicycle stunt pegs for side handles on the angle grinders I put wire wheels on. I like the extra weight they add and they are a bit more durable than the plastic ones, or at least the plastic ones that come on HF grinders.
Besides the aircraft floorboards my cart was built around, the metal all came from a commercial clothing rack and the bottle holders are aircraft seat belt extensions. Like the ones the flight attendants show you during the safety announcement at the beginning of each flight.
IMCA38
Bennet, NE
I recently picked up a well used Magliner aluminum convertible hand truck. After cutting it down, reassembling, and adding a few accessories, I have a great cart for my arc welder.
scout4bta
Willcox Arizona
Lift pump for the Jeep Liberty Diesel
I repurposed the steel fuel line from a 89 jeep Grand Wagoneer. Other than cutting the line in half and adding a few more degrees to the inlet side it's as is.
I did have to purchase the 1 1/2" conduit strap for the filter support other than that the steel is what I had laying around.
lis2323
Very nice job[emoji481]
lis2323
This industrial pipe threading machine by Ostler Manufacturing...
was
converted into a twisting machine for wrought iron work. It will twist 5/8” steel square stock COLD.
Bears Fan
Indiana
Lis
Awesome idea and restoration on the pipe threader, great looking shop too :beer:
Did you make your own decal for that too?
lis2323
Lis
No! I stumbled onto it poking around on the net. The company makes fishing lures and the Canadian distributor was kind enough to send me decals free of charge.
For that I am grateful and hope they aren’t upset with their end use.
lis2323
Lis-
That is a great restoration too! I love the Mister Twister branding!
-JD
Thanks,JD! As noted in previous post I can’t take credit for the branding as the name was already taken. [emoji3]
drivesitfar
LIS: MISTER TWISTER looks like a handy tool. can you still use it to thread pipe if you wanted to?
great vision and nice work. did you make the Mr. Twister decals or were those the ones the company sent you?
WELL DONE SIR!!
Shootinok: great idea for some temp storage.
ALL: speaking of storage my mom saved all her 1 gallon ice cream containers and I don't need them so anybody local to me that can use them just let me know cause she even saved the lids too. I bet there are 20 or 30 of them.
Copymutt
Colorado
Not a big deal, but the tall Folgers plastic coffee containers are the perfect size to brine, marinade a duck. Much less liquid needed and full immersion.
IMCA38
Bennet, NE
was
That thing looks cool as heck! Awesome restoration as well!
I’d love to see some video of it doin’ it’s thing.
VWingman
Ferguson
I had to go back and forth to make sure I was looking at the same thing. That thing is gorgeous and the perfect repurposing.
BD1
north side
I have a RIDGID 400 pipe machine. I haven't done any twisting yet but made lots rings.
I use standard schedule 40 pipe with a slot cut in one end. I stick the 1/4 round rod into it and use foot pedal for controlling. Takes about a minute to roll rings from a 10' long piece.
BD1
north side
Ok Lis now you got me thinking about a twister/roller.
I'm thinking about a couple of adjustable roller bearings to roll larger rings in a three point set up.
BD1 good idea for smaller stuff
Sent from my SM-A102U using Tapatalk
Machine chuck is 2" schedule 40 pipe capacity. I have used 3" and 4" pipe for rings. Just welded steel on center of one end of pipe with a 3/4" bolt that goes into chuck. Works well. I highly recommend using a foot pedal for control and safety.
lis2323
You mentioned that to me before and I’ve kept it mind for future projects. I’ll have to give it a try. And you are right about using a foot switch. Much safer and EASIER. [emoji41]
BD1
north side
Some metal art from recycled parts. The green bird and saw blade owl can also be adapted for in ground. Screw in a all thread rod to backside and stick in ground.
Dutch01
Kempton Park, South Africa
OK this is a tongue-in-the-cheek repurposed item. I took an old desk top computer power cable with 2 connections - electric kettle fittings - which I cut off and fitted new female double connectors to the ends. A nice to have when using multiple electric tools.
Craptain
Tampa Bay FL
Dutch, where the hell are you that is still using those plugs and sockets?
Last time I saw them was in Sri Lanka. Even there they are switching to the later rectangular pins.
Sent from my SM-G930T using Tapatalk
Dutch01
Good old South Africa. A lot of the electrical appliances that are not cordless still have the small plug on the right of the photo, eg. kettles, ups's
The plug and socket as above are still standard equipment but I have heard there is intention to phase them out.
harley jim
Cleveland Tn..........out in the sticks
I was given this machine crate it is 17'x 7'x 6' high it is completely lined with galvanized metal I cut a door in the end and now have a critter proof garden shed7e821206dd8c59de08c287ec3e71e687.jpga9ab26a3c1ed6de4cbd0b2d9e36962d7.jpg4e6cd0fa56be16b1e314cb6755eae794.jpg838c29cf0f3d781ee3b46c457caeed55.jpgd2ad00487e9b1da927f2a9634379235c.jpg
zjrog
Tooele, Ut
Old watered was taking up space in my basement. I stacked the pedestals and used the 3 platform pieces to make a solid workbench in my basement. Perfect for bicycles, computers and firearms...
Sent from my SM-G975U using The Garage Journal mobile app
OCD
Edmonton, Ab. Canada
Came up with an idea to use a couple of empty cardboard tubes...
Used a chunk of pex and the zip ties to keep the heat shrink from falling over!!
Dutch01
Did some cleaning up in the far end of the backyard and found this old bird cage stand. With the help of pallet wood, plastic potting trays and scrap metal, some cutting and welding, I went from this:
to this
Dutch01
Very cool, amazing that is so sturdy to hold all that weight.
Thanks. Don't know why I haven't made a welding trolley long time ago. I am a bit concerned about the plastic office chair type wheel though, but they seem to been holding up well so far. Will replace with more appropriate wheels if and when they fail.
paulsomlo
Northern Colorado
Old plunger, drilled a hole in the handle to hang it by - makes a handy dispenser for a roll of blue shop towels.
