sqyards
UPDATE: lol ok so I started sanding anvil and slide (got more to do) but looking better atleast I think. thats for the advice on sanding it..
thanks for the tip still fixing my 1st vise projectMe too with the JB Weld for filling minor saw marks on the tops of jaw towers.
Here’s a trick I learned from somebody on GJ years ago. You can avoid the overly smooth look of epoxy by pressing in some sandpaper of the appropriate grade (you’ll have to experiment with this yourself...different grits and application after different curing times will give different results.
That gives you texture mimicking cast iron.
When you tool the epoxy, you can lay a piece of Saran Wrap on to minimize tool marks.
Here are 2 shots of my last project taken mid way. I experimented with a skim coat of JB Weld with no texturing.
You’ve got to clamp the vise body down to something immovable. Get the biggest crescent wrench you can find (I’d be happy to loan you my 24 incher) pull some tension on it and have somebody whack the end with a BFH for the “ impact”. That just might work. (I assume you’ve already soaked it with penetrating oil)
I have had success with a much larger drag link socket and an electric impact wrench. Using that tool it’s not so important to immobilize the vise body.
replacement vice from the one I broke a month ago. Its a little weathered but will do the trick.
Where’s my Reed guys? I’m not crazy that this comes out like a regular bolt? Lol thing is in there good.
I have a 1/2” one but that wasn’t working. I made something that for tighter out of some bar stock with a crescent wrench also not budging
Boy maybe I lucked out on my Reed 403 as it was hex head and not slotted.
But I did end up buying an extra large socket as my 3/4" drive set didn't have that exact size was
1-9/16". Did have 1-5/8 but was too loose a fit and I didn't want to damage the corners.
Then again maybe it actually cost me in the long run because I first got a 6 point but was an impact and I' ll be danged with thicker sidewalls it didn't fit in the recess so ended buying twice and got a 12 point chromie instead to do the deed
See that same bolt here...https://www.garagejournal.com/forum/showpost.php?p=6549446&postcount=28
I dimensioned out it for another GJ member whose vise was missing that part
Good luck with that one
On old Harleys we made a draglink type socket by welding in a piece of flat stock of the right thickness to a socket that been slotted a little
I have a gigantic Williams drag link that I used with my electric impact. I had to bolt it in a vise, a 16” breaker bar wouldn’t do it. If you can’t get one quick from Amazon, I can mail mine across the Bay. Mine is 1-1/4” wide by 3/32 thick, about $15 to my door.
I just ordered the same size right before I saw this. Maybe you were the comment on Amazon about using it for a vise! It’s 4 days out tho. I’m in no rush.
That almost looks like it has a verdigris patina!
My new Parkinson Samsonia Perfect 37 Model J all steel vise.
Found this looking for vises. A shop built into a container . Insulated walls, full electircal, Pretty interesting as it even has AC, might give some of you some planning ideas during the quarantine. It is in listed as a complete shop with contents being for sale in Brookville, Florida ($19750), but they are willing to ship. You could get a lot of vises in one of these...
Thanks. Yes, it seems to be in very nice condition. Jaws are good, very little hammer marks on the vise itself but the handle has some, quick action works.Looks like a very nice example just in need of a good cleaning and some rust removal.
This is a Leavens Jersey vise no. 45 it has 2” jaws, opens 2” and weighs in at 3 1/2 lbs. What I find really interesting is that this vise has been nickel plated. There are still large portions visible on the slide, handle and cylinder. There are no markings on the slide but there are stamps on the anvil. The front stamp says Leavens Co Vineland NJ
Stanley Jersey did offer a nickel plated vise no. 663N so this could be its predecessor. The large stamp on the anvil appears to be a 62 it’s hard to read.
Sent from my iPad using The Garage Journal mobile app
It's Rustoleum Forged Hammered Antique Pewter. Not sure if the Forged designation is new or not but it's a color I hadn't seen before and I'm happy with the results.Here are a few pics of my big drag link socket that works flawlessly on slotted Reed and Athol shoulder bolts. The one pictured is the A15 which is the largest 1/2" drive @ 1 3/16 blade width but I ended up buying an A17 also which is a bit smaller @ 15/16". These can be found on Ebay often for around $10-15.
Oh and speeking of Athol vises, I finally got around to choosing a color and painting my 624N.It's Rustoleum Forged Hammered Antique Pewter. Not sure if the Forged designation is new or not but it's a color I hadn't seen before and I'm happy with the results.
A few pages back I posted some photos of my son's vise. Here are some better shots. It's a Columbian No. 63 "Red Arrow". The dynamic jaw support was snapped off and there was quite a lot of slop in the bore of the dynamic. I pressed in an oilite bushing for the leadscrew and shimmed the split washer. Tightened it right up. This particular homeowner grade vise has no jaw inserts and any knurling (if it had any) is long worn off. It came from a basement workbench in an old 1940's house. Anyone have an idea on age?
I’ve seen a restoration video where they mark off a grid and use a cut off wheel to cut it in to create some jaw teeth. Could be an option
I have thought about doing something like that on a couple worn fixed jaw faces i have at least maybe make some file cuts
Many times it’s handy to have a vise with smooth jaws so you don’t mar your work piece. Other times it’s nice to have sharp teeth jaws for heavy duty work where you’re not concerned with marks.
Here’s a novel idea...have more than one vise to use for different purposes!![]()
My Red Arrow also has smooth jaws. Apparently that was the way they came from the factory.
