Relex
Picked up the blower and grinder to add to the collection last weekend.
subarub4
Connecticut
So far trying to use the mid torque on some wheel bearing bolts not too happy right now I’m not sure if the torque rating goes down as the battery drops to 1 bar but it’s still not coming out.
dsilver1007
Honea Path SC
Battery charge makes a pretty big difference with impacts I believe.
M635_Guy
NC
Which battery are you using?
I wouldn't expect too much from one bar, but it seems like it should be able to do it unless that's a really highly-torqued nut.
DFB
Southern VT/Western Mass
One bar is pretty weak for using the impact. Power really does drop off. Give it a full charge and see what happens.
Wheel bearing bolts should come out pretty easy with a Mid Torque I would think
There was one time though some 1/2" bolt nut combos beat my Mid torque. I was dissembling an old bolted up hay wagon frame. Mid just rattled away to no avail.
Was no match for the the High Torque though :D
danny_barkley
FL
Don't know what vehicle you are working on but, I am doing a complete front suspension/bearing/hub/flange refurb on an 18 year old Land Cruiser and the Mid Tq is not straining on anything. Lots of my stuff torqued from the factory to 120-170# and that was 18 years ago. Zipping everything off. I have the 8 amp batteries. I start with the 3/8 stubby and go to the mid TQ if need be. I wouldn't try to do anything at 1 bar though.
subarub4
Connecticut
Still never got it to remove the bolt fresh off the charger I ended up using a breaker bar on it kinda disappointed since everybody raves over it so much. I’m using the m18 XC battery.
Looks like the bolts had some type of lock tite on them too
subarub4
Connecticut
That’s what happened to me the mid torque just ran without moving at all the fact that I got it off with a breaker bar and body weight kinda makes me wonder if this thing is really 600 ft.lbs
dacan23
RI
Best evidence of tool dropoff when battery goes to 1 bar is the leaf blower, its so much you can't help but notice.
DFB
Well there's always that one :spit:
Fortunately you were able to get a breaker bar on it. On a lot of jobs using long leverage often can easily do it over impacting. Though impacting often best if anything has a tendency to rotate on you while you are trying to remove it
Simply put "Locktite" and depending on the formula strength can be a *****. We recently did brake rotor bolts on a motorcycle wheel that were locktighted sealed in there, The only way we freed them without destroying the bolt heads (as these were countersunk internal hex) was to use heat and plenty of it to soften up the threadlocker compound.
subarub4
Connecticut
Yeah I was in HD yesterday i was pissed I didn’t pick up a torch I did get all 4 bolts off now it’s trying to get the damn hub out.. Have to run to HD again to get some long bolts to push the hub out from the wheel studs.
Bighead38
Rockland County NY
This man right here knows what’s up. There are some times I look at a bolt and know the mid torque won’t touch it. So I break out the pb blaster, heat, and a breaker bar. Sometimes it’s just heat and the mid torque. Sometimes it’s a combination of everything. The breaker bar provides a constant action and if your a bigger guy you can put a lot of constant force on it. The quick impacts just aren’t enough to break it free a lot of times.
subarub4
Connecticut
This man right here knows what’s up. There are some times I look at a bolt and know the mud torque won’t touch it. So I break out the pb blaster, heat, and a breaker bar. Sometimes it’s just heat and the mid torque. Sometimes it’s a combination of everything. The breaker bar provides a constant action and if your a bigger guy you can put a lot of constant force on it. The quick impacts just aren’t enough to break it free a lot of times.
Speaking of quick impacts I had the 1/2” brushed one before I think it’s like 450ft.lbs Maybe it’s just me but it felt like the impacts are a bit stronger.. the new mid torque reminds me of the Milwaukee hammer drill I had before.
I used pb blaster on it and all it was no go and a high torque would not fit in that area at all.
davethorik
Norka, Ohio
Thinking about picking up the m18 string trimmer. I just moved into a house after apartment dwelling for many years and realized i don't have any lawncare equipment. Hd has the trimmer, 9ah battery and rapid charger for $269.99 but i have to have it delivered to store. Nbd, lawn is mowed but will look like **** a few days lol
I have been doing reading on the web and it seems to get good reviews. Yay or nay?
DerekV
Central TX
The trimmer is excellent. It has never left me wanting more.
davethorik
Norka, Ohio
Thank you Derek. I think im gonna pull the trigger. I need a rapid charger anyway, i have a ho xc8.0 for my fuel circ saw and it takes very long to charge on the std. charger. This will fit in well with my collection, oh well didnt get a free blower or anything.
I compared this to an echo gas trimmer also for $200, both got real good reviews. This a bit more w/ rapid charger and 9.0 batt. I'd have to buy a gas container, gas, and 2 stroke mix for a gas trimmer. And string for either.
setfocus
rust belt
I have the trimmer as well, it has decent power and they say 1 hour run time on 9ah batt. I like that it has different attachments like some gas models. I got the edger too, never doing that by hand again. They also make an indexing hedge trimmer and pole saw
Rusty67
LA, CA
I have almost all the attachments for the string trimmer and I love it. I don't have the hedge trimmer since I had the older dedicated hedge trimmer already. I actually really like my dedicated hedge trimmer unit quite a bit as well, used it this weekend.
darkzero
SoCal
Finally got tired of the chuck on my 2nd gen Fuel. Installed the upgrade chuck today. Man what a difference, feels like a whole new drill now. Can't believe I didn't do this sooner. ***** that I even had to this. I've never had to replace a chuck on any of my prev drills.
DerekV
Central TX
[emoji106]
lafester
Northern CO
I ordered my first round of M12 tools to start replacing my Nextec stuff.
I went with the Fuel impact and drill set with the free ratchet from HD.
I found a refurbished caulk gun at CPO for $85 so that is coming as well.
Looking to add the staple gun, rotary tool and possibly the cutoff tool.
Not positive yet, still looking at reviews and such.
Over time I will probably snag most of them as they go on sale or pop up on FB.
I went with DeWalt for the big tools but they have nothing to compare to the M12 line.
I will have a Yellow shelf and a Red shelf and hopefully they will get along.
MikeF2316
Thornhill, ON
I replaced the chuck on my corded Craftsman drill many years ago because (as) it wouldn't grip drills properly - they were always spinning in the chuck. And I've replaced the wobbly chuck in my Chinese drill press, with a $5 garage sale find. Wobble went from .010" to less than .001", it was a great improvement, and like you, I didn't understand why I didn't do it sooner!
My Milwaukee drills are, thankfully, free of wobble.
Is that screw left or right hand thread?
starquestMM
JC, Missouri
Thats the actual milwaukee one correct? Can you get it outside of a warrantee work?
ddurrett896
VA
Just got a m18 15 gauge nailer (2743-20). Expensive, but man it's so nice not dragging a hose around the house the couple times a year I need one.
darkzero
SoCal
I see. Yeah this is the first time for me. My chuck didn't have the weeble wobbles. I replaced it cause/as (;)) the locking mechanism was messed up & the chuck would slip when using drill bits close to 1/2" also. I have a drill bit set with the 3 flats on them so that pretty much took care of the slipping issue but the locking part would act up every once in a while.
The screw is left hand & the chuck itself is right hand.
Yeah. I got it from a replacement parts seller on ebay. I didn't want to spend more for the Rohm.
kppolich
Eastern Iowa
Milwaukee Resident, Milwaukee now replacing Dewalt in my house.
Question:
I want to get the Large Packout. Can anyone tell me how much space is left from the bottom of the storage tray when installed to the bottom of the case inside?
I'd like to do 2 layers of tools in Kaizen, but I'm not sure if there is enough room to have 2 layers of tools and keep the storage tray.
I'd like the top of the box to have 2 storage trays.
Middle Layer would have Hammer Drill/Impact and 2 bit cases
Bottom layer would have charger and Hackzall.
If there isn't enough room, I'd likely go the the rolling packout and do 3 layers of tools with liftout layers.
Thanks!
setfocus
rust belt
So yesterday I had to drill out a bolt on a mazda 5. The pinch bolt for the strut to knuckle connection. All I have is the old makita 12v max (not cxt) drill. It seemed to have enough power (it did get warm) but I went through both batteries and had to borrow a coworkers drill to finish
would a M12 fuel drill with larger XC batt be good for drilling out the occasional bolt or should I bump up to the M18 fuel?
DFB
Ya I have the angled 16 for years now...great having it. I use it more than I ever imagined especially to quick tack stuff in place before other nailing or screws, getting something up and level I work by myself alot so makes things nice :D
In fact it did that just yesterday making up some raised bed frames for the garden. Afterwards I did drag my pancake compressor outside the garage to the nearest exterior outlet and then ran 100ft of hose to shoot the galvi framing nails to secure everything after it it was assembled and squared up using the cordless first
Let me tell hauling all that pneumatic stuff out SUCKED...its so old school BS these days
I always have laugh SMH on some of the treads when these people go ooooh yaaa oh my 20 year old corded or air tool is better...
mostly because they don't own or use any of this :pimpflash
Cannot wait for the cordless framing gun to be available and on sale
I bitched to myself today about just that... I said out loud to myself after setting up all that stuff I'd pay $500 for that tool right now. :beer:
Hopefully its a lot less than that :lol_hitti
Sparkyftw
Minnesota
I almost bought one of the nailers, but just could not justify the cost for something I only have a few tasks for. If I already had an 18v battery and charger I would have grabbed one though
I also wish milwaukee sold a tracksaw in the U.S. I feel so dirty looking at other brands
techieman33
Kansas
According to this video NPS2020 is postponed indefinitely. Sounds like new tools will still be launching, we just won't get it all at once.
nitroracer20
NY
My 2 x milwaukee m18 1/4” impact drivers keep having what i believe to be circuitry issues
Intermittently, They Will still impact, but spin “freely” when i let go of trigger. To reverse direction, i need to remove the battery, reverse the switch, and reinsert the battery.
Disappointed - i use them pretty hard for framing/deck work, but nothing i feel is excessive.
Multiple different batteries - same issue
Are the fuel models better? Anyone had same problems. Ill upload model number when i get to garage later
DFB
Never heard of that particular issue before..
So are you saying that even after you release the trigger the motor keeps running and driver tip keeps turning? :headscrat
nitroracer20
NY
Not quite.
It will freewheel to a stop - and not immediately stop like a traditional impact driver. The LED illumination light stays lit up until you disconnect the battery. And it emits a low volume, but high pitched whine until battery is disconnected .
