This is all hypothetical. Goal is to make design decisions now in the right way to reduce “rework/throw away work” in the future.
I currently have a 50amp interlock on a 200amp main (single) indoor panel. Meter is outside. So imagine meter -> 4/0 SER -> 200 amp panel indoors with 50 amp double pole interlock.
This was done properly with UL listed parts, permits were pulled, inspector signed off - all good.
Question : Imagine in far (or not so far) future I get a 400 amp service. Multiple ways this would work, but I think most practical is two parallel 200 amp lines from meter (double tap) into two indoor panels.
- In this system, are the inside 200 amp panels considered main or sub panels?
- How would one make the interlock work in this case? Can you simply wire a second interlock double pole in the second panel, then simply place a junction box on the existing 6-3 and splice the current generator cable and feed both panels?
- If I were to get a stand by generator (say generac), can I get the 22 kW version or am I now stuck with a much bigger 40 kW generator now that I have 400 amp service?
The reason why I am asking for all of these questions is because the more I think about my projects and future plans, the more I realize my 200 amp service now will be borderline load calc wise when my first set of tools arrive and I want to build things right the first time. That being said, we lose power at least 5-6 times/year and I love my generator and the ability of controlling which switches get power.
