Rockwell 1124 floor drill press?
thewaydown
midvale
I picked up a Rockwell model 1124 floor drill press today for $100.
I know its supposed to be a lot better quality than the crappy craftsman one I have. Anyone own one of these specific models or know about the quality? The first couple things I've noticed right off is its missing the quill feed handle and the chuck key (jacobs no.3 1/2"). Its going to need some pretty heavy rust removal/paint, a new belt, and possibly new quill bearings.
Is this jacobs no.3 chuck decent?
If anyone has any good sources for parts that would be awesome.
tool_scrounge
Southern California
lafester
Northern CO
Yeah eBay should have everything you need. Might as well grab a 3 handle hub...
Sent from my Pixel 3 XL using Tapatalk
tool_scrounge
Southern California
One comment:
Be sure to lubricate the splindle splined shaft and the mating surface of the spindle pulley. I see that as a wear spot on a number of this series of drill press due to lack of maintenance.
How to tell if it is worn:
Hold the spindle pulley stationary with one had and turn the spindle back and forth to see how much flop there is in the splined interface. Lots of slop shows you have wear.
T
thewaydown
midvale
One comment:
Thanks for the info. Ill check that out today.
I can't seem to find a manual for the 1124 anywhere. I've checked all over Google and vintage machinery. I was thinking it might be the same as the 15-081 but when I checked the range of models that manual covers, the 1124 isn't listed.
Sent from my SM-G986U using Tapatalk
T
thewaydown
midvale
One comment:
How much slop is too much? and exactly where should I lubricate? What lubricant?
I uploaded a video to demonstrate how much slop there is on my DP:
larry_g
oregon
To much slop is when the spindle splines are 100% gone. Yours looks great. I have the same machine and the handle is just a straight rod from the factory. It was their economy model, no balls.
on edit;
below is a picture of a air spring I add under the table to help lift it. It is a 30lb spring and can be had from McMaster carr.
https://www.garagejournal.com/forum/attachment.php?attachmentid=148023&d=1320595905
lg
no neat sig line
T
thewaydown
midvale
on edit;
lg
no neat sig line
That is an excellent idea! I have actually been looking around for a good lift/lift assist idea for the table, and was considering using the counterweight method. I'll have to check this one out as well, thanks a lot.
