Heating any building to a given temperature takes a certain amount of BTUs.
Holding the heat in.......is a function of the insulation and air exchange rate.
So as far as run time to heat and bankruptcy:
120,000 btu for one hour
60,000 btu for two hours
30,000 btu for four hours
Cost about the same in fuel. Electricity varies slightly because for fan on time but slightly because a larger unit will likely have a larger fan motors.
Bankruptcy is a BIG heater and ( no) poor insulation or leaving the door open in the winter.
Run a reasonable sized heater and insulate and seal the building.
Your other conclusions are spot on with seal burners, in floor, constant heat, higher cost of the units with more features.
