Vintage Counter Restoration
MAYOR28
Southern MD
My wife (she's pretty amazing) found these on Craigslist a long while ago. Unfortunately we did not have the space for them inside the shop until recently. That meant they spent the majority of the last year out in the elements. They were already a little rusty, so really the only damage is on the delaminated tops (which I was planning to replace anyhow).
My plan is to do a quick repaint, and paint the pitted chrome with some aluminum paint. The question is this: What color do I paint the main body?
turbowoodworker
Apex NC
First off, those look too cool to repaint pitted chrome with silver paint. Do your painting then polish the chrome with all its warts. See what it looks like. You can always paint it later, but vintage chrome should stay vintage (IMO).
What does the front look like? Drawers, cabinets?
What color are you looking for, what theme? Ford blue, Harley orange...?
What kind o laminate are you looking to do? There are too many laminate colors to consider.
Pick your preferred color family, see what laminate you can find (afford) and then pick a paint to match.
Great project there. We all want pictures of the progress and final product!
Rick
:beer:
turbowoodworker
Apex NC
Sorry for multiple posts but I had one other thought looking at the picture.
The edging on the old laminate looks like it might be aluminum, typical of the stuff stuck on the sides of Formica tops way back when. I would consider polishing those up (easy) or replacing with more aluminum.
MAYOR28
Southern MD
Rick
:beer:
I hadn't considered trying to polish the chrome. I was actually thinking of trying to get them re-chromed, but don't know of any local places to do that. As for color scheme, I will put another picture down below with the current garage set up. I have a green(ish) floor, galvanized metal wainscoting, and off-white-washed walls. My other cabinets are black (or going to be black) and aluminum colored hammer-tone. I have a lot to repaint since I got a bunch of file cabinets free lately......
Might want to ask these questions of your wife. Sounds like she might be very helpful.
Yessir! She certainly has a vote.
The edging on the old laminate looks like it might be aluminum............. I would consider polishing those up (easy)
Yep, keeping those. A little polish and reinstall on the new tops!
MAYOR28
Southern MD
I forgot to answer the laminate question. I am planning on remaking the tops with an mdf or plywood core and press-board/masonite on the very top. That way I can replace the very top layer easily. I may also add a set of MFT table holes ('dog' holes) to half of one top.
I will need to get a picture of the back side of the cabinets. They are just open cavities. Looks like one was modified with some sort of angled shelving that I was going to remove. I will most likely build a bunch of finger-joint plywood boxes to store tools and equipment in these spaces. Things like tablesaw jigs, and larger tool fixtures, not hand tools.
driftpin
One cheap & easy treatment for pitted chrome, which I've used (when you discover the cost of re-chroming, you're gonna 'just say, no') is to use a bicarbonate of soda (NaHCO3) blaster to scour the pits. Be careful of disposal of the bicarbonate of soda as it kills the grass. Then use a 'ball' of aluminum foil and rub it into the pits, vigorously. This costs next-to nothing, the NaHCO3 scours the pits thoroughly, better-than any paste can, and it leaves no residual material. I think you will be surprised at how-well it works.
As a comment on your color choice, I think choosing something to 'pop' in the room will add to the look. I assume your cabinet backs will be to the wall, so except for the front perimeter edges, you won't see the cabinets' color, except for the end cabinet, assuming it stops before the wall.
MAYOR28
Southern MD
I will have to look into the bicarbonate of soda.
The cabinets will actually be out in the open, facing the 'middle' garage bay. So you will see the large painted face all the time. They will kind of be a focal point. I can post a rough layout later today.
cdestuck
Altoona, Pa
Take your wife to Lowe’s or H-D. Paint dept, oil base Rustoleum quarts and pick from the colors available. Easy peasy.
MoonRise
Oh no, you absolutely HAVE to have the metal cabinets media blasted down to clean steel, then some body work with hammer and dolly and some body filler and block sanding until it is as smooth as a mirror, then several coats of primer, more block sanding, then multiple coats of basecoat in a transchromatic midnight purple metallic, then some wet sanding, then several coats of clearcoat, followed by more wet sanding and then buffing and polishing until it as deeply glossy as the finish on a Boesendorfer Concert Grand 290 Imperial in full classic ebony gloss black.
And the counter just MUST be some Swedish green marble.
https://en.wikipedia.org/wiki/Swedish_green_marble
:lol:
What vibe/feel do you want to achieve with these cabinets?
Utilitarian? Classic 'shop' green/gray industrial.
Somewhat funky? Gulf livery pale-blue and orange.
https://modular4kc.com/2011/04/22/design-friday-the-color-of-gulf-racing/
Really utilitarian? Black hammertone.
Oriental vibe? Deep red with black trim.
Don't just "quick repaint" them though. Take at least some time and effort to clean up the rust and such before repainting.
The aluminum trim rim could be removed from the old counters and cleaned up and then at least somewhat buffed/rubbed/polished to the desired gloss/sheen anywhere from a brushed-type finish all the way to a gloss polished look.
MAYOR28
Southern MD
Definitely will take some time to clean up the rust. Just not doing the suggested full body work....:lol_hitti They would be too nice to work on then.....
MAYOR28
Southern MD
Attached is the planned layout. The 'counters' are the bright green hatched rectangles.
HotrodHR
North Alabama
Pick a color, any color... but if it was mine I would do the "bodywork" as some mentioned and shoot an automotive type single stage or basecoat/clearcoat paint, redo the top with some retro looking Formica. Polish the aluminum pieces (start by sanding to remove deep scratches, followed by finer and finer sand paper, and then polish - plenty of YouTube demos online).
For the chrome trim, try to find some in your area that does Spectra chrome or cosmic chrome parts painting - this stuff looks pretty good. Eastwood offers a DIY product, I haven't used it though so I can't speak to how good it is.
I get trying to keep stuff original, but this is a case where a partial restoration or repair will just make this look like an old repainted counter... restore it and you'll have a cool retro counter... you might even want to add some pinstripe details to add to the cool factor.
:beer:
MAYOR28
Southern MD
:beer:
Good idea on the Spectra Chrome.
I will do some body work on it in areas that are very rusty, I am just not going to do a full automotive restoration. I want to use the shop, I'm getting rather tired of working on the shop. Trying to knock out these projects so I can get things to the final location and start working!
K'ledgeBldr
Johns Creek, GA
+++ on the Spectra Chrome.
It's a great alternative to replating- especially for something that won't be exposed to the elements.
Check with body shops for the Spectra.
MAYOR28
Southern MD
Back from the dead! Time to resurrect this thread!
The wife and I finally got around to tackling this project. Went a little deeper than intended, some disassembly of the interior, but I am very happy with the results so far.
MAYOR28
Southern MD
Started with stripping most of the major rust off the cabinets. Angle grinder and wire wheel, plus a quick wash made them ready for paint.
Overall, they were not in bad shape, considering they sat outside for nearly 20 months.
These are before stripping:
MAYOR28
Southern MD
Started off with Rust-Oleum Rusty Metal Primer.
We also decided to disassemble the shelves so that I could reconfigure them during the rebuild. Here they are primed.
MAYOR28
Southern MD
Final Color! We decided on red to match the tool cabinets in the shop. Eventually the other metal cabinets (file cabinets throughout) will be painted black and silver, so I wanted these to stand out a little.
This is Rust-Oleum Ford Red from Tractor Supply. It is close to the Harbor Freight Red, but not an exact match. But it was on sale for $34 a gallon, so the price was right.
First coat (eww):
Second coat (looking better):
Reassembly:
Trying to place it in its final home:
MAYOR28
Southern MD
I riveted the shelves back in (only 2, trying to decide what to do with the other 2 still). Then it was on to the tops. They will be laminated MDF, 1.5" total thickness with a sacrificial masonite/pressboard top.
Realize too late that the glue makes the tops slide apart as you clamp them, panic, and go find big clamps......
Ready to be cut to final size:
MAYOR28
Southern MD
I was nervous to cut the radii on the corners, then I looked at the old tops and realized that it was actually a very small radius, so the task should be much easier. I test fit various sockets into the aluminum trim rings until I found the right size, then used that to file/sand a plywood template.
Unfortunately, the only flush trim bit (top-bearing) I have was not long enough to cut the whole thickness, so we had to make one pass with the template and one without.
Then I rounded the bottom edge, up to where the trim ring will sit. I will paint this exposed MDF black to contrast the aluminum trim ring.
With sacrificial top cut to size.
And that is where we stand today. I am waiting on a slot-cutting router bit to make the rabbet for the trim ring. Hopefully that comes in the mail this week, and we can cross this project off the list.
MAYOR28
Southern MD
I thought I had some pictures of the chrome pieces, but I couldn't find them......will need to take some more.
But, they are in pretty bad shape. So I think I am going to paint them with some Seymour Cast Blast. If I hate the way they look, I will eventually find some way to get them re-chromed.
Sawdust_
NY
I must admit I didn't see where you were going with this project until I saw the final product. LOOKING GREAT!
Well done.
MAYOR28
Southern MD
The plan for this workbench is to put a vise on the corner closest to the lift post. That will give me a solid vise location for the automotive side of the shop. Then the short side or back side (haven't decided yet) will have a permanent mounting hole patter for a few of my tools. I am thinking the bench-top arbor press, a bench grinder (or two), and a wire wheel setup. I will mount each of those to larger baseplates with the mating hole pattern, then it will be a simple bolt down install. Just need to make some sort of nut-plate for the underside of the top.
Still waiting on USPS to deliver my slotting bits so I can get the trim installed back on the edges......
Stuart in MN
Minneapolis
That's a smart idea, then you can take them off and put them somewhere out of the way when you aren't using them.
For the chrome parts I'd try soaking them in Evaporust or similar first, to see if they'll clean up well enough to use as is.
Jayman17
Seattle, Wa
Mayor, very nice results on your workbench resto. The color looks great too.
Please update when you get the trim ring installed and the other pieces of trim as well.
Jay
MAYOR28
Southern MD
Been stalled since USPS hasn't been able to deliver my slotting bits :argue:
Finished the reinforcing piece on the one (don't worry, I'll paint that screw later):
Marked out a few of the existing mounting holes.
Unfortunately, I could not find long enough #10 CSK machine screws at Ace (the not-so-helpful place this time). So I was stuck with some 1/4 carriage bolts. That meant I had to counter-bore the top a bit.
I love cluttering up horizontal surfaces......
MAYOR28
Southern MD
Just in case the sacrificial pressboard got spilled on, I wanted to seal the MDF underneath. 2 quick coats of shellac, and that is done.
