Maxjax - Depressurizing hoses for removal
danieldd
Southern Tennesseee
I am taking the MaxJax down because we are moving. I have to disconnect the hoses from both the columns and the hydraulic unit. Am I going to get soaked in transmission fluid when I disconnect from the hydraulic unit?
D
danieldd
Southern Tennesseee
Okay. Thanks. The spring loaded couplers I understand I won't loose much. Its the other side that connects to the hydraulic unit I was worried about. But as you say, if the arms are completely down, then I should be able to disconnect and there shouldn't be any pressure on the lines.
