ClappedOutBport
- Joined
- Mar 30, 2016
- Messages
- 998
Unless you're at risk of snapping it in two, or your heart desires to JB weld it for appearance, I would recommend leaving it alone.
Good Job!I silver soldered up a huge gash in my disc grinder table and it worked like a charm.
This is a Craftsman-badged Walker Turner SD-80 that was appears in the Sears and Roebuck catalogs in 1933 and 1934. Unless my research is flawed, it's the first drill press to wear the Craftsman name. This was a fun build, using two machines that came to me both missing parts. Fortunately, between the two of them I came up with a complete machine. Powered by a period-correct Kenmore 1/3hp motor.
What is it?Granted I could have taken more time to fill in the pin holes, maybe sometime.
Yeah It Is Nice Job, Nice Paint job too.Wow, that came out to be a total museum piece! Nice job!
Super jealous of your long c press!
Way back in the archive of this thread, I saw a note (from a 1-post user) saying he had to look up a patent application to figure out how to fix (restore?) an old, unique press.
What's the best way to look up patent applications? I've stumbled across a few in Google searches, but not consistently.
I'm trying to make up for the lack of available info for my (presumably) Langelier sensitive drill (model number unknown, but I've stumbled across pics of several different possibilities).
Mike
I think it's an Atlas model 70 from the 1930s. Just started restoring it! (If you know of anyone with a spare motor base with the vertical adjustment bar, I'm looking for one...)
View media item 102681View media item 102679View media item 102683
Do you have the patent number? you can also search for the mfg in the patent files I believe, and that might get you to the company the it was assigned to?
I'm curious as to how the research gurus do it as well. I've used Google Patents with hit or miss results.
Sweeeeeeeeet!
Is that an Oliver by chance?![]()
OH Wow, 16" Nice!!No it's a max 16 inch form about the mid 50s
JoCoSawdust that's a great looking drill press. Is that an original color ?
Oh No, it looks great. Not a lot of gloss, in this case, better yet IMO.It's close to the original color, should be a little bit darker but I don't have the equipment to mix and spray custom color so..rattle can it is. I've seen so many variations of original color on machines if this era I don't think anyone knows exactly what color they were. I went with this color since it has the slight violet hue to it that I see in the nooks and crannies of original machines.
Oregon Rock Crusher ,That is truly a Beauty, it had me muttering to myself when I was looking at the pictures. I thought my Wife was going to think I was going Crazy.
Or being confirmed crazy ! Nice ! Thanks
No, I don't have a patent number. I found a government patent site with a search feature, but for anything before 1975, you have a very limited number of search criteria to use, and name isn't one of them...
Craftsman DP100 table top model, with Atlas made XY table/vise and middle pulley.
Brian
