Wiha Precision Screwdriver Master Set: Thoughts & Organization
pizza
Midwest, USA
wiha offers 50-piece 'master sets' of their precision screwdrivers in various flavors:
Master Technicians Bench Top 50 Piece Precision Screwdriver Set (92190)
Master Technicians Bench Top 50 Piece Precision Screwdriver Set With Pentalobe (92189)
ESD Safe Master Technicians 50 Piece Set (92092)
and a picofinish one:
50 Piece ESD Safe PicoFinish® Precision Screwdriver Master Set (92093)
overall, they're great drivers. the tips are among the best.
i have some minor complaints however.
first of all, the printing on the handles is kind of inconsistent.
some yellow, some gray, some white ink.
some printed straight, some printed crooked.
some printed fine, some bold, some blurry.
also, some of the spinning end caps spin freely while others have appreciable friction.
the visual in my head is guys picking from huge bins of combined manufacturing runs and sealing them in bags as the 50pc master set.
also, i am not really satisfied with the bench stand.
it's arranged as a grid of 10x5 holes, and there's no way to organize the drivers that makes sense to me. since it has rows of 10, you can't get everything of one drive type in one row, so you have spillover. there are also no extra holes.
to make matters worse, the size and drive type are not printed on the end caps (except for picofinish!), so it's not easy to tell which driver is which in that stand. this is especially true if you want to organize by drive type. they're all different lengths, so you'll have taller drivers obscuring the view of shorter drivers. if you don't care about organizing it that way, and you just put all the tallest drivers in the back, it's a little easier to see what's what, but i just don't feel that this stand is a good organizational system.
i think that they should have made the stand a bit bigger with more holes and longer rows so that you can organize in a sane way. this would also give you some room for expansion. in the ESD set for example, i think there's 12 torx drivers and 15 hex drivers. i think it would have been much better to have the holes in a 15x4 or better yet 15x5 grid. this would permit you to organize the rows like this for example:
  • phillips + slotted
  • torx
  • hex
  • nut drivers
and then you could put odds and ends like the chip lifter wherever it makes sense to you, and you'd still have a few extra slots.
instead of the stand, i actually have my set in two tool rolls:
they're called Yasutomo Niji Roll Multi-purpose Pouch (about 6 bucks each). i think they're of reasonable quality.
this allowed me to lay them out in a way that makes sense to me, and they're also portable.
if you look carefully, i have two empty slots between each drive system. this gives a rudimentary form of tool control (visual check that no tools are missing), and it also breaks up the tool density in the pouch which allows it to roll up better.
to be honest, i mostly use the roll on top with the phillips, slotted, and torx. to this roll, i have also added some extra tools including a pentalobe size 4, some spudgers, scrapers, and a scalpel. the other roll with the hex and nut drivers doesn't get used nearly as much.
anyone else have a precision driver organizational system they're happy with?
here's a link to an imgur album of the pics in this post:
http://imgur.com/a/QNx7zbK
measuredtwice
USA
That was quick! Did you get next day delivery?
I've also noticed the stuck caps and have mentioned it in comparison to PB Swiss, which spin better than Wiha or Wera. There's likely some flash on the plastic parts. If you turn them back and forth, it'll sometimes loosen up. The Wera caps can be popped off without causing damage so that you remove any flash. I don't recall if you can remove the caps on Wiha or if it will damage them--maybe best not to try.
Hadn't previously seen that pencil roll. It's an efficient use of space, especially since you alternate the orientation. I have the Wiha roll and the handles are all on one side so it bunches up on one side.
Steve_P
I have mine in Schaller trays : one tray for each type of driver. I grab the tray for what I need . All of mine have nice white inking and no issues with the caps not easily spinning
jjkrjh
I bought this set when they were on sale elsewhere.
https://www.kctoolco.com/wiha-92191-master-technicians-precision-screwdriver-set-51-pieces/
And added this set later for our lovely Apple products
https://www.kctoolco.com/wiha-26794-precision-pentalobe-screwdriver-set-pl1-pl6/
They all fit nice in a drawer with the cardboard box that they came in. Tray is labeled along with a printed sheet that I've taped to lid to locate correct drivers. All of the drivers are labeled consistently without any blemishes. It has been a nice set---no complaints.
P
pizza
Midwest, USA
no, i already had that set. the one i ordered during the sale is a gift for my brother.
but then i made another order just before the sale ended for a picofinish master set. i may keep the picofinish upgrade for myself and give him my old set (pictured in the OP). if so, i'll return the regular set i got in the first order.
yeah, i've tried popping a cap off to clean it up, but it didn't seem to want to give. i chickened out because i didn't want to break it, haha
P
pizza
Midwest, USA
dang, i knew i missed something during the sale. i should've gotten the full set of pentalobes. i have a PL4, and that's all i've needed so far for a retina macbook pro, but who knows what i might need in the future.
nice. that tray is imo much nicer than the metal bench stand.
cheechi
Triad, NC
I prefer the red handled non ESD set. I have the interchangeable bit ESD set for when it's needed. All my spinners spin freely even the drivers I rarely or never use. I do notice a few of them are printed with older/different style marking but it doesn't bother me enough to matter. I would like if they had markings on the top but I'm mostly over that too.
Love the metal stand. Truthfully I only use 6-8 at the very most, I have muscle memory to grab those and keep them in size order for the odd times I need the rest of the set. Downside is there is no room for the Pentalobe set or a triangle set.
Never been a huge fan of tool rolls, the bigger the less i like them. Yours look like they work for you and I'm glad for that. I count myself lucky if I need to toss a cheaper multi bit micro set in my bag I can get by, and I get to use the nice drivers in a more controlled setting.
pugglewuggle
TX
I have this same set (ESD version) and the organizer annoys me too. Wiha tips are the best. It would be great if there were a zipper version of your rollups. I’d be a lot more happy with that than with the stand. Also, the tray that was posted is too thick to fit in a thin toolbox drawer. Grrr.
