I have a Miller 211 which runs off 110/220 depending on which plug you use. I don't weld anything super thick right now as I'm a basic beginner, so I've been using 110. If I get into heavier gauge, I would like the 220 option.
Based on this thread from Miller's forum, it sounds like as little as 30AMPS but up to 50AMPS is OK. I might opt for 40AMPS and split the difference
https://forum.millerwelds.com/forum/welding-discussions/33366-miller-211-what-size-breaker
I have a generic 240 Vac outlet in the front of the garage for my plasma cutter and MIG (when I get one). My compressor is on the same 240 ckt, but I have a switch to turn it off so I'm not running both at the same time.
So, what you're saying is if I have GFCI outlets at the BEGINNING of the circuit, I should be OK? I will do two GFCIs-one at the beginning of the outlet wiring and one at the beginning of the overhead lighting. Is this correct/consistent with what you were saying?
Correct...first outlet GFCI and all the other outlets off the load side of the GFCI
I can make sure I have a dedicated 240 outlet for my welder which will have a properly sized gauge wire. I also have a 240 compressor which will likely be on the same circuit. But since I only have two hands, I won't be using them simultaneously.
I do the same thing
I plan to only have outlets wired into the wiring into which the LED ballasts plug. The draw/requirement on my electrical system will be minimal due to their low draw. I am only thinking one switch for the whole garage (roughly 27' long x 20' deep). I like the idea and concept of "overbuilding" as it is in my Germanic roots to do so
I'm using 18 recessed LED lights set in 3 zones. I actually like it that way. Quite often I'll be working in only one part of the garage. All the lights and garage door opener are on the same ckt.
I am leaning toward running it in the walls because I don't feel that conduit will provide me with the tidiness I am after. With my garage, I have a somewhat limited need and I plan to overdo the install the first time. If I sell it and someone wants to add on afterward, that's their prerogative.
If you are going to drywall...I'd do Romex in the walls. That way your wiring is not in the way. in the 12 years since I've built mine, I have not had the need to 'modify' anything.
So, for running Harbor Freight and Costco brand LED lights, 14/2 will be beefy enough? I plan on the 12/2 for wall outlets as I have plenty of cool tools to plug in
I need to decide if I want to set up a table saw in my garage or get it hoisted into the upstairs of my barn. I have a 40'x50' area in my barn upstairs that would make a great woodworking shop.
That is what I would do.
One 120 volt 20 amp circuit should suffice for my needs. I'm more of a tinkerer/hobbyist with a day job than a professional who needs the space for a professional purpose. I don't want to under-do it but I think I'll be fine.
Personally, I'd run 2 20A ckts. That is how mine is set up....I have outlets about every 6' and they alternate ckts. That way I can run 2 high amp loads at once if need be....like...my central dust collector and table saw at the same time....
Also...I'd suggest putting the outlets about 54" from the floor. That way you can lean a 4x8 sheet of something against the wall and not block it.
I don't have a furnace in my garage, and don't know that it would work that well. I plan to insulate the whole thing once I get the electrical installed and the walls sheathed and painted. I'm going to do the same thing I did with my last place. Insulate, paint the sheathing, install wall sheathing, have lots of lights. Right now, its a bit...dungeonesque
