compressor pipe size?
caleb90
at home
alright, so the junk kobalt i had is back to lowes. got my new compressor home tuesday. i ended up with a napa unit, same as the belaire 216v. they gave me a great out the door price that i couldnt refuse. any ways i got the spot picked out for where its going and im trying to figure up materials to plumb it in. the bung in the tank is 1/2in and is welded in with a 1/2in ball valve. my main run to my work bay will be about 30ft or so. should i bump up to a 3/4in adaptor and run 3/4in main line or just keep with the 1/2in and the bung in the tank will be the bottle neck to begin with? also plan on using copper pipe, l m or k thickness? thanks
matt_i
SE Michigan
Any of the Cu pipe sold has pressure ratings appropriate for the pressures in an air system.
I'd jst run 1/2", will be cheaper. Unless you have something like a sandblast cabinet thats going to be continuous run.
lis2323
Remember to use a flexible jumper between the valve and the hard piping...3 foot long or so.
^^^That ......and what the others said regarding 1/2” copper being more than adequate.
Marctrees
TX/LA border - Toledo Bend
Easiest cheapest way for that is off shelf hydraulic hose specifically at TSC usually for best price... they have different lengths like 1' - 6' or so ... or your NAPA, but probably more $.
Insulates the hard pipe from vibration and dampens vib noise.
Marc
They come w standard male pipe thread both ends same
https://www.tractorsupply.com/tsc/p...x-24-in-3-500-psi-hydraulic-hose?cm_vc=-10005
C
caleb90
at home
I doubt that, i have always found tractor supply to be pricey. there kind of a novelty shop. plus i get shop prices at my local napa:)
nadogail
Coronado, CA
Any hydraulic supply shop can fix you up with a hose. I personally would consider a sharkbite flex hose like I use to hook up waterheaters.
C
caleb90
at home
all plumed in. very happy with out come
C
caleb90
at home
I would be curious what you end up paying for the NAPA hose ... please post size and price when you get it.
Marc
35 bucks for 1/2 hose and fittings. 16 in overall length, 1/2npt female on one end 1/2in slip male fitting on other end. the slip/jointed male fitting is what drove the cost up
Pontiac787
New Hampshire
I think TSC prices are regional. In my area they are usually the most expensive shop in town.
LS6 Tommy
Northern NJ
Nice job. I'd suggest terminating that power cord in a proper box on the wall with a whip to the compressor.
Tommy
