TT_Vert
Basically I blew it and didn't think to run two neutrals for the two circuits in the same run and I have no way to pull another wire through the pvc conduit I used due to bends, etc. I had to pull a string through w/ a vacuum as my fish tape kept getting caught on the joints. I have 1 14 AWG wire feeding 3 outlets, one 12 AWG feeding a pump and the shared 12AWG neutral. Also I have the shared 14 AWG ground to all devices. Is there ANYTHING I can do short of running a neutral to get this functioning as I need it to function? I assume if I were to forego the GCFI breaker and put in GCFI outlets I'd still have the same issue correct? I'm so annoyed w/ myself for not considering I'd need two neutrals when using GCFI. This is feeding a pump which sits outdoors under a deck as well as outlets sitting under that same deck so I feel I need GCFI. What if I repurpose my ground as a 2nd neutral?
Thanks guys
Dave
Thanks guys
Dave
