how to calculate starting capacitor
Jvvmusme
Bogota, Colombia
can someone help me calculate the correct starting capacitor for this electric motor.
thanks
jose
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
That probably means that the centrifugal switch does not open.
Several reasons:
Gummed up mechanix
Contacts welded
Motor overloaded and does not reach rating plate RPM
This is also likely to overheat the starting winding.
You will know by the winding color and also the smell of overheated wire insulation.
But first of all.
Are you having the proper voltage on the input terminals?
Ola
J
Jvvmusme
Bogota, Colombia
i have proper voltage
yes it overheats
changed all cables to new ones
proper gauge
changed centrifugal switch and testested for proper open close operation
and its ok
remained the same problem
what is the starting winding ?
no understand
thanks
Bert_
NW Iowa
it will burn every starting capacitor i use after a few hours and it tets real hot
The start capacitor should be switched completely out of the circuit once the motor is up to speed. The start switch inside the motor does this.
If it doesn't get switched out the start capacitor will be fried in just a minute or two.
