That probably means that the centrifugal switch does not open.
Several reasons:
Gummed up mechanix
Contacts welded
Motor overloaded and does not reach rating plate RPM
This is also likely to overheat the starting winding.
You will know by the winding color and also the smell of overheated wire insulation.
But first of all.
Are you having the proper voltage on the input terminals?
Ola
