Vise Info Thread
cclfn
NW
The "mechanism" that locks the swivel base and rotation of the Yost rotator vises is just a large through bolt to which the lever is threaded onto.
Here are some pics of a 4 1/2" Yost swivel jaw rotator I acquired last year. You can see that the "barrel" that slips over the swivel base and accepts the static jaw (nothing is really "static on this vise") is partially cut down the middle and it's essentially just pinched when that bolt is tightened.
Great photos thanks for the informative post.
KMScott
Charles Parker 201. 2-1/2" Stationary vise that opens to 3-1/2" and weights 17lbs.
KMScott
Vanderman #0 Steam Fitter's vise. 4-1/2" jaws and weights 50 lbs.
KMScott
H. B. Smith #1464. possibly the model number. No spec;s on this swivel base vise but wanted to record it.
KMScott
Prentiss #71 and #74 Quick release vise. #71 has 3-3/4 jaws that opens to 4-1/2" and weights 33 lbs. The #74 has 5-1/2" jaws that opens to 8" and weights 98 lbs.
KMScott
Massey Clinoher #37. 7" jaws that opens to 10" and weights 205lbs.
Shiftless
East Bay SFO
Here is my HB Smith
It’s marked 1 comma A
Maybe that’s a foundry error ??
Jaws 3 3/4 inches wide but there are signs they’ve been narrowed a bit.
4 1/2 inch clamping capacity
The slide was damaged and the pipe jaws missing when I bought it but how often do you run across these?
It weighs 42 pounds including the base plate. I don’t have the threaded post or the wingnut.
PghJKB
Industrial Heartland
Here is my HB Smith
That patent date looks to be August 1, 1865. That would be patent #49094 (a palindrome) granted to H.B. Dart for the pipe jaws.
Patent located here:
https://pdfpiw.uspto.gov/.piw?PageN...%26S1=0049094.PN.%26OS=pn/49094%26RS=PN/49094
And here:
https://patents.google.com/patent/US49094A/en?oq=us49094
The patent shows what looks like a simple nut rather than a Ram's Horn, jaws are Very Parkerish....
JKB
GETRIDAONE
Auburn, GA
Parker #87 vs Smith 1A side view. I got curious about the pipe jaws, they are a perfect fit in the Parker except for the cross pin is in a different location.
There are definitely similar features in the two vises.
PghJKB
Get,
Dart's patent has also appeared on Parker vises.
Scan Man Jeppen may have image that show's the Dart Patent on a Parker.
JKB
Fierljeppen
Get,
"Scan Man Jeppen" may have image that show's the Dart Patent on a Parker.
JKB
You've got it right, that style combination vise is all about the Dart patent. I think that you could add Meadville's combo vise into this mix as well.
H.B. Smith is still an active company after being founded in the mid 1850's. They were most famous for manufacturing boilers, while the Dart patent vise was more of line card item offered for the pipe-fitters. They mfg. the vise up to the early 1900's, when it appears The Oswego Tool Co. started making combo vises for H.B. Smith, Parker and a private labeled vise for the Oil Well Supply Co.
The Dart patent vise had several style changes over the years, but always retained a sense of the original patent. I'm personally very fond of these vises and own a couple of examples of them.
GETRIDAONE
Auburn, GA
I added the Meadville type in the picture but this one is cast J. S. & Co.
The one on the right is another Parker. I have a 289 1/2" but it is to heavy and not convenient to put in the picture of old combo vises.
KMScott
Hollands 46. Stationary model. 5" Jaws. Second Hollands I have seen with the same model # but one being Stationary and one being a swivel base.
KMScott
G. ******* Tool & Die. Clamp-on with pipe jaws. 1-7/8 jaw width.
damon18
Memphis, TN
Can this be identified from this one picture?
Just one bad picture, the shape seems like Wilton bullet but no Wilton name visible, maybe the old ones didn't have it or on the other side? Are there cheap vises with similar shape to Bullets?
KMScott
Looks like a Wilton Tradesman vise to me. There is cheaper vises but I feel this one is made in the USA al tho used heavily.
KMScott
Lehigh Quick Release Clamp-on. 2-1/2" jaws that opens to 2" and weights 6lbs.
damon18
Memphis, TN
Thanks, I won't be able to see it in person for a while. Every picture of a Wilton like that I've seen has included cast in raised letters spelling out Wilton, were there models shaped like this that didn't? Maybe just a sticker, paint, or metal plate that could have been worn off?
Vise
NE
Athol Catalog - Undated
AngryBeaver
Lake Milton Ohio
look for pictures of wilton tradesman's. that appears to be a model 1750
KMScott
Athol #16. 4" jaws. Stationary base
davethorik
Norka, Ohio
Dropfo vises. The 3" opens 5.5" and weighs 22 lbs. The 5" opens 8" and weighs 48 lbs.
davethorik
Norka, Ohio
Erie tool works 00C. 2.5" jaw combo vise, weighs 13 lbs and opens 2". Dont know if this is in the spreadsheet .
KMScott
Hollands 642. 4-1/2" Swivel Jaw that opens to 8"
KMScott
Prentiss 912 swivel jaw. 3-1/2" jaws.
KMScott
Prentiss 945. Stationary base with 5-1/2" jaws.
KMScott
Charles Parker 69X. 5-1/2" jaws that opens to 9" and weights 129 lbs.
KMScott
Trojan / Parker 727. 5-1/2" jaws that opens to 8" and weights 113 lbs.
Fierljeppen
I'm looking for help identifying the cars and year in the Wilton no. 835 brochure below. This will help us put a more solid date on the beginning of the Wilton Tradesman "1700 series" and "740 series" mechanics vises.
My first inclination is late 1960's Ford, GTO and Mercury? But, I'm looking for more knowledgeable eyes than my own. Thanks in advance!
Dandy Dave
Copake, NY
The car in the middle is a 1969 Pontiac GTO.
