Above 1200 Sq/FT 86's 20HP shop
Strouty
Southern Maine
I hate it when you try and do the right thing only to fail miserably. :(
Hope you have been able to get some more done, looks like having the tractor working is good timing now that the weather is starting to level off.
86turbodsl
Got some oil tanks setup and the truck emptied out. Knocked a bunch of paint off the lathe. Think I'm going to setup a electrolysis tank this weekend and hit the lathe hard. I need it bad. I never go to work anymore so I am out of options.
Sent from my LG-TP450 using Tapatalk
ClappedOutBport
Clapped Out Bport, you don't read very well do you.
" or is it a diesel?"
I read fine. I was just trying to point out that diesels don't have condensers or coils, hence, no point in asking. If you didn't know, well that's alright. Sorry if I sounded like an ***.
Tractor still giving me fits. It's cutting out under load. I replaced the condensor this morning. It's still doing it. I think next step is replace coil. I don't know what else to replace, i'm running out of ammo for the parts cannon.
How old is the tractor, does it have vacuum advance on the distributor or is it a diesel?
86turbodsl
It's all good guys. We're all adults here. Most of the time anyway. ;)
I found out last night that there are slight differences in IBC tote sizes. My tote is smaller than the tote i got the oil out of.
Ask me how i know...
86turbodsl
Been spending a lot of time working on the lathe. Parts of it all over the shop and I need it running. The rain hasn't been cooperating so lift beams aren't getting scrubbed.
86turbodsl
Memorial day weekend 2020.
Shop fire edition.
You heard that right. Been cleaning the shop. Getting rid of stuff I don't need and finishing small projects. Years ago my wife knocked my big shop fan over and busted the grill surround. I used it without for years but always was worried I was going to chop my head off around it. Found a grill at a yard sale last year for 5 bucks. Finally got around to putting it on this weekend.
I repurposed the plastic trash can to a sawhorse to get it sitting flat while I worked. Made a few tack welds and then decided to break for lunch. Came back an hour and a half later to find this mess.
Lost my grinder, torch head, and mig lead.
It had to have smoldered for at least an hour. Came out just in time to see the last of the flames. No apparent other damage.
Expensive lesson.
27f572efd4b4cb5d13c7091d4467f155.jpgbe4139ef5ad78e63dffcd619fbc7b2da.jpgd86e5b887feeeef4df8d4bce3091f3e9.jpgeec437bdba5abb9e715f0e408f45f19a.jpgdef3265e9ec4cf2432bcaa502d85412d.jpg
bimmer1980
York, PA
Yikes!!! Good thing the torch was not pressured with gas from the regulators or the whole shop would be gone!
It *****, but a reminder to be careful in the shop...
I had some things stacked on a plastic oil pan the other weekend....came out to seeing the pan partially collapsed and a massive puddle of oil on the shop floor.... Spent the whole day cleaning it up... Floor dry, then soap and washer, rinse and repeat...
We are our own worst enemy at times...
86turbodsl
Yes, good thing i am positively religious about turning the gas off always. Or it would have ALL been gone. It took over an hour for the smoke to clear with fans in the windows and the big door open. I think the torch handle is rebuildable, the fan is ok, and the mig lead and grinder are toast.
It's a $500 mistake.
ClappedOutBport
Indeed. That is frightening. Garbage cans have been the cause of multiple fires on this forum, including our very own site administrator. https://www.garagejournal.com/forum/showthread.php?t=358438
I'm super glad that no one got injured and the shop didn't burn down. $500 hurts, but as far as the flip side, that was a very cheap lesson. Stay safe.
86turbodsl
Thanks. I'm super happy that's all i lost. Could have been much worse. A reminder to not be careless.
86turbodsl
Well after all the drama last couple of days, i did score one win. I found the problem with my syncrowave. I moved the pedal to work on the fan shroud and it quit working again. Cable! I ordered another cable and we'll see how it goes with that. the old one does have a couple of taped spots.
And I got a wonderful steak dinner courtesy Mrs. Turbo.
50ae6e1b4dd266a242e2ebfe61b1a5f4.jpg4072e01370d20a780ae1b9b0251ef284.jpg9519ac4eaa154e4e04747cbbdaa0ffdf.jpg
The 500 dollar fan...
Strouty
Southern Maine
Glad it didn’t take off, I try and hang around for a good half hour after welding and cutting, I figure that should be enough time to see if anything is going to catch on fire.
1Garageman
Columbus, Ohio
So glad that you are OK after the fire, and nothing major was damaged!!! Makes me wondering if I should put a smoke alarm in our garage?
86turbodsl
Yeah I forgot I should do that. I often don't keep safety procedures in the front of my brain. *****.
86turbodsl
Thank you. Smoke alarm would have done nothing. Sprinklers is only thing that would have helped.
ClappedOutBport
Don't you have high ceilings? I highly doubt the fire would have been hot enough to activate them.
An internet connected smoke alarm on the other hand....
86turbodsl
14ft. Not sure how hot it got up there but no black mark on the steel at all. Lots of smoke though. Took a couple hours to get it all out.
Strouty
Southern Maine
Sounds like what happens whenever I start my L10 Cummins inside.
I figure if it is 90 here, you are probably seeing some of the same, too hot, too early for me. :(
86turbodsl
It was hot here for a few days, but it cooled off again. Been cleaning for days. And this followed me home. Pretty serviceable condition. Even managed to figure out how to pick up without wrecking it. Now it needs a home.9396f3852b22cf8c2576d4f27396def7.jpg
ClappedOutBport
Nice! Not keeping that one? Looks like just the right size. 16" Grob? Dad bought a 24" cuz it was cheap and it's just too damn big.
ClappedOutBport
Is that one on of the belt reduction models, 86? That would be a bit of a bummer if so. The 4 speed gearbox they put on some of them is really nice. The reeves drive is pretty unnecessary though except for production.
bimmer1980
York, PA
Nice looking saw.... Before you go crazy with it, I would release the tension on the blade and check the bearings for the wheels.... Not that I'm recommending to go diving into another project, but it's worth it to check....
I'm currently in the process of rebuilding a horizontal 9x16 saw and it "only" needed a new set of wheels.... that has turned into a full rebuild with bearings, etc... I'm going to try to sand blast and paint.......ug.... I rather wish I had not bought it.....
86turbodsl
It is the belt model. I did not want a gearbox or anything complicated.
ClappedOutBport
It's dead simple by gearbox standards. Just a few sliding gears and enough room to hide your retirement stash. The guy that had it before dad never filled the oil after shipping apparently, as it was dry but doesn't leak. Who knows how long it ran dry. :eek: Some gear damage but not enough to require any repair.
I've been into his pretty deep, so lemme know if you need any advice. The one issue I never could figure out is that the lower blade guide is not adjustable regarding in and out, so it doesn't do much with thinner blades.
86turbodsl
Got my flashback arrestors and put the new torch handle together. That's officially operational again. I think i might work on the AC plumbing tonight. It's a HOT one out there.
86turbodsl
Thanks, it needs a little tuning, but not much. Price was sure right. Nobody wants old anymore. I don't get it.
matt_i
SE Michigan
Oh Boy! Someone's been shopping at HGR :D I recognize the format of those numbers in green lol!!!
Great potential there, hope it turns out to be a diamond for you!
That place is like a gravitational pull to me, I can't seem to ever get fully away from it :D
86turbodsl
It's like a candy store to me. Almost always make the full rounds. Not much fun with the mask though
I really need a forklift...
86turbodsl
Got a wild hair today and got the injectors unstuck on the Detroit. Now I want to hear it run dammit.
