BRIDGEPORT 8F X-AXIS POWER FEED help ?
sweetk30
finger lakes area upstate ,ny
my friend has a older bridgport mill and his power feed is broken . he dosnt use it a lot but sure does miss it .
anyone know a good repair place for them or is it cheeper to just get a good used or new unit ?
pic of his style model i found .
any leads would be great . i kind of want this as a surprise for all the favors he has done for me . :bowdown::bowdown::thumbup::thumbup:
BLUE72CAMARO
IL
A little more description on what isnt working would help. If its not powering up check the fuse holder I had to replace one on a mill at a shop I was working at when I was going thru trade school.
matt_i
SE Michigan
From what I recall its a DC drive on a circuit board.
At one point replacement boards were available but I think Minarik had a DC drive that would work in its place. I think its just a 90vdc drive.
This is just a google search I don't know them nor their products.
https://www.machinerypartsdepot.com/store/1478157/page/712426
I have one in part or whole somewhere. Buying the new leadscrew with the extended shaft to interface with that is what held me back. A person can't just acquire that and bolt it on to a standard Bpt. The additional-length leadscrew must also be purchased/sourced/acquired unlike the ones currently available which are "bolt on kits".
Grant Gunderson
Bellingham, WA
I fully rebuilt a Servo brand unit this spring. Really simple to work on once you open them up so as long as you can get parts it’s a DIY project. Might be worth checking the limit switch. That’s more likely the cause of the issue then a bad board...
Bigblue&Goldie
I've been kicking around the idea of just going to a Servo unit. It will be about $1k for a genuine Servo. I'm just not sure sinking a few hundred bucks into a 6F is worth it in the long run. 8F it would be a no brainer.
bsg
Imlay City, MI
Matt, IIRC you can buy a leadscrew extension for a standard screw to use with your power feed?
If your screw is in good shape, that maybe the way to go?
Kevin
matt_i
SE Michigan
Kevin
Good stuff, Kevin. I was trying to research HQT to see the options but got stalled. I sort of gave up on the idea after I got the Fadal, its a much better milling machine. Just use the Bridgeport for squaring stuff up and drilling/tapping these days. Maybe time to "let it go" :bounce:
