Colin Len
I'm a complete irrigation novice and I know it's not rocket science but I have a project that won't be easy to alter once complete so I need to get it right the first time. We currently have no irrigation on our property and will eventually hire a company to install new sod and irrigation. When they do this I want them to add a few extra valves that can be connected to our raised vegetable planters for drip irrigation.
I don't want to pay them to run the actual lines INTO the planters. Partly because I'd like to save a few bucks but mostly because I will be redoing some pavers around two of the planters and want to run the necessary plumbing under those pavers now and provide a stub for the landscapers to tap into. I'm not entirely sure what methods may be ideal for this vs "no, don't do it that way!".
My plan was to install a vertical section of PVC into each planter with a stub sticking above ground that I can connect to drip tubing later. That vertical PVC pipe would go deeper than the sides of the planter, connect to a 90deg elbow and then to another section of PVC which would run under the pavers and into the grass area. I'd cap off that pipe for the landscapers to tap into later and connect to an irrigation valve. A crude representation is attached to this post. Below are my questions but please let me know if there's anything else I need to know or be concerned about.
Thanks in advance for any knowledge you'd like to share
- What size PVC should I use? 1/2"? 3/4"?
- Where would the pressure regulator usually be installed? Do I need to worry about this now or will it be installed nearer to the valves and something I can leave to the landscapers?
- Are there any considerations I need to factor in for connecting this PVC to poly drip tubing? (I assume using PVC is best for this situation as it needs to be reliable so I never have to dig these pavers up again.)
Is there an optimal depth to install the stub under the turf? I don't want to get in the way of any other irrigation they will be running but don't want to make it so deep it's not accessible.
