Pressingonward
Hi everyone, I've got a 70's Ford 1000 tractor that recently suffered a bit of a mishap - the left front axle knee broke (cast iron, looks like it's been cracked for quite a while before it broke), and in the process of the wheel falling off, it bent the steering centerlink that connects the left and right spindles to each other.
I was able to find a good used knee axle, and what I thought was the correct centerlink. Tonight I discovered that the new centerlink is definitely not going to work - it uses RH threads on the tie rod end and mine uses LH threads. I'm sure I could track down the right rod end eventually, but I'd like to get my tractor back up and running ASAP, preferably tomorrow...
So that leads to my question - what's the best way to fix this thing?
The pipe measures 27.5mm, or just under 1 1/8" OD. I can't measure the ID, but it is thin-walled. I don't know if it is iron or steel. One end is welded to an obviously cast piece, but again I don't know whether it is cast iron or cast steel:
I don't have a pipe bender, but I do have a press and lots of junk to fabricate fixtures out of. The pipe is already slightly deformed at the bend, which makes me worried I'll flatten it further if I try to bend it straight again. My other thought is to cut out the bent section and weld in a replacement piece. I'm comfortable doing this as long as it's steel pipe...
What do you guys suggest? Here's a closeup of the bend:
The suggestion to use 3/4" Black Pipe is a No-No black pipe [or any conduit/fence pipe etc.] isn't tough enough for anything structural, use "Erew" [welded seam] at a minimum, DOM would be considered SOP for most safety critical parts. For the speed of most farm tractors EREW would most likely be fine and on the shelf at most steel houses in a size you could bore out to fit [1.250" Dia.X 0.187 wall. will have an inside Dia. of ~0.875" but will not be round with a seam also. Hope this helps. Harry
), then stacked the two halves next to each other and screwed them together to make a block that is 3" wide. I finished cleaning up the "U" with a round file, out to 26.5mm - I figured the softwood would crush the extra half millimeter and better support the tube than if I went for a perfect line fit right out of the gate - plus I was tired of filing
