Bushing for bench grinder
Slimls
Hello all!
I recently purchased a 8" Delta bench grinder and put on buffing and wire wheels. When I put the them on I found out that both wheels were too narrow to tighten down and they were very close to the motor. I went to the hardware store and pick up a bunch of washers for a temporary fix. See below. Does anyone know where I can pick up a bushing or have one made? The shaft is 5/8".
Thanks,
Slim
Slimls
No joy with bushing at the hardware store...I looked/asked.
Thanks for the link to McMasters.
greg13
Weedsport, NY
In the REAL hardware stores (not the big box stores) check the draw isle that has all the odd ball stuff.
Old Radar
San Antonio, TX
The problem with washers is for any given size, the hole is a larger diameter than that stated size. Works great for a stationary fitting, but on an arbor that's spinning at 3600 rpm or faster, that slop induces vibration. Now use four washers--one on each side of your two wheels--and you most likely will tighten them down while gravity is pulling them all in the same direction and now your grinder starts beating itself to death. McMaster's bushings will cost more but when you tune your grinder (yes, you need to tune it) you can rest a coin on the grinder and it will sit there.
2oolhound
BC Canada
I think you need spacers not bushings. A bushing goes inside the hole in the wheel and fits tightly on the shaft. A spacer goes between the side of the wheel and the tightening nut.
bubinga
:beer::beer::beer::beer::beer::beer::beer::beer: :pimpflash
This!:thumbup::thumbup:
@ the OP.................
IF indeed it's a bushing you come to find out you need,
My Lathe should be back up and running with in 2 weeks, and lf you do need a Bushing:confused:
I will make you one. :thumbup::thumbup:
But Wait! Message before Midnight tonight, and You will get, Not one, But Two bushing, (Just pay a separate fee)
Operators are standing by, Call now, THE CALL IS FREE!! LMAO!
:lol_hitti
Ok, maybe I'm not ready for a career in stand up comedy,
But all kidding aside, :bowdown:
I can make you one (Just cover the postage fee)
Just private message me.
ClarkShort
San Diego, CA
I had a similar issue and used one of these:
I had enough space to mount it on the non-threaded portion of the 5/8 shaft.
I think I ordered a set from Amazon:
https://www.amazon.com/Climax-2C-062-Two-Piece-Clamping-Plating/dp/B002081ZHM/ref=sr_1_4?crid=KFB9Y4CNGL2G&dchild=1&keywords=5%2F8+collar+with+set+screw&qid=1590155986&sprefix=5%2F8+coll%2Caps%2C305&sr=8-4
Slimls
Thanks guys! Yeah, spacer would be the appropriate term.
I'll give the "OILITE BRONZE BUSHING" eBay listing a shot. If that doesn't work out I'll hit you up Mr. Bubinga. :thumbup:
bubinga
I'll give the "OILITE BRONZE BUSHING" eBay listing a shot.:thumbup::thumbup:
If that doesn't work out :beer: I'll hit you up Mr. Bubinga.:beer: :thumbup:
"Mr. Bubinga"....................LOL.........................I LIKE THAT:beer:
(I'll hit you up Mr. Bubinga.)
Any-Time Bro................. Just private message me!!
Spacers are readity avaible on line, 0r at A hardware store, Lowes, Home depot, etc.
Welcome....................Slimls, I just noticed:shocking: :thumbup::thumbup: you're a new member:beer:
STICK AROUND NOW!!!!!! one of THE BEST, If Not THE BEST!!!
Groups Known To The WWW.XXXXX
bubinga
I had enough space to mount it on the non-threaded portion of the 5/8 shaft.:bowdown: :bowdown: :bowdown: :bowdown: :thumbup: :thumbup: :thumbup: :thumbup:
https://www.amazon.com/dp/B002081ZHM/?tag=atomicindus08-20
ClarkShort,...............................................................
I Had brought A few of these a while back. :thumbup: :thumbup: :thumbup:
I CRS these days, forget what the application was,
but worked out quite well!!!!!................. :thumbup: :beer: :bounce:
Still Have one floating around someplace, :thumbup:
Milton Shaw
Just get a 5/8 shaft collar and use it. Most hardware stores would know exactly what that is. They have 1/2, 5/8 and 3/4 in the same assortment box. You don't need to tighten down the set screw but leave it in and use lock tite on it to keep it from vibrating out. Problem solved.
