OK MAYBE we are there! The Sears Jr lantern PU tube that has been giving me fits finally quit acting like a one way valve after all the prior cleaning, plus overnight in MEK, plus more cleaning, plus heat and quenching several times. So I tried it and it has fuel! I let the valve flush a bit, then added the genny, and YES! a steady stream at wide open valve! turned the cleaner several time and its good.
I put a few things away and its still going so keeping my fingers crossed!
Burning bright:
I did have time yesterday to do some detailed cleaning so the fount is clean if not pristine, Someone clamped it in a vise at some time in its past, so it has two flats from that, otherwise just paint scrapes. Apparently the font was plated with the something (cadmium? I don't believe galvanize). Greze-off, did a great job removing the gunge.
I also spent some time on the vent as it has plenty of porcelain damage but it also had rust stains on the porcelain, still has some old slightly darker paint someone rattle canned on, and soot and rust underweight on the white porcelain. other then the gunge, all THAT sneered at the Greze-off, so I tried a short soak with paper towel soaked in Simple Green (hoping to make progress son the old paint). A LITTLE rust stain came off but not a lot. nothing was making any serious dent in the rust or soot...
So its porcelain, and I've been in and out of out near new porcelain kitchen sink , and decided to try the Soft Scrub Cleanser SWMBO likes so well and almost ALL of it came off! Maybe a ten min soak and then some scrubbing with paper towel?
This might be worth a tray of blackened globes?
So it still looks like the battered old solder it is,but it now looks like an old solder that has had a shower!
Some shots of the vent - I may try an overnight immersion in SG for the old paint...
Fingers crossed it STAYS that way!
